I’m trying to initiate debugging using avr-stub on an ATmega2560 (arduino). I’ve simplified my project as much as possible. It seems to compile, load, and try to start debugging when it gets:
========================= [SUCCESS] Took 3.05 seconds =========================
Reading symbols from /home/don/Documents/PlatformIO/Projects/Testing/.pio/build/megaatmega2560/firmware.elf...
done.
PlatformIO: debug_tool = avr-stub
SERIAL_PORT: No such file or directory.
Since it loads, I presume at least vscode is detecting the proper port.
and my code is: #include “Arduino.h” #include “…/.pio/libdeps/megaatmega2560/avr-debugger/avr8-stub/avr8-stub.h” #define PIN_LED_8 (8u) #define DIGIT_1 PIN_LED_8
debug_init();
breakpoint();
pinMode(DIGIT_1, OUTPUT);
digitalWrite(DIGIT_1, LOW);
delay(500);
digitalWrite(DIGIT_1, HIGH);
delay(500);
breakpoint();
for (int i = 5; i > 0; i--) {
delay(500);
delay(500);
for (int i = 50; i > 0; i--) {
delay(50);
delay(50);
I’ve verified that everything works if I don’t try to debug it. I’m at a bit of a loss about what may be wrong. Any help appreciated.
–Don
You’re supposed to put the serial port you’re connecting to here. Go into your Windows device manager and check for the serial ports named “COM…”. The last COM port is porobably the right one. Then put that COM port name instead of SERIAL_PORT.
Thx, I’m on Ubuntu and it is otherwise detecting the port (ttyacm0, I believe). You are saying that platform.ini operates differently when starting gdb? or the port is somehow properly detected for loading, but not executing (maybe it’s known by my system, but doesn’t get to the board for reverse communication??), or …
I’ve stumbled with port problems before, so I’m not surprised here. I was thinking the name SERIAL_PORT was already bound to the proper port during the build.
You can also try it without and see if PIO’s auto-detect port logic kicks in. PIO could probably do it automatically, but if it says in the docs that you should give it a serial port, better to do so.
platformio.ini files can use externally-bound variable names but that is then with a $ prefix, e.g. $UPLOAD_PORT or $PROJECT_PACKAGES_DIR (example docs)
I hate to be thick here, but I’ve tried both ttyS0 and ttyACM0 (both identified when running pio device list). I get the same error:
done.
ttyACM0: No such file or directory.
I have:
debug_port = ttyACM0
Since the complaint is about a file or directory, I would assume that the issue has to do with a file/directory on my system, not on the board under test.
