Names and version look all correct, maybe try and remove external-repo
fields, it should source it from the registry.
What dependencies does it detect for BingMachine in the dependency graph at the start of compilation?
|-- <Adafruit DRV2605 Library> 1.2.0
| |-- <BingMachine>
| | |-- <SdFat> 1.1.0
| | | |-- <SPI> 1.0
| | |-- <ArduinoMD5>
| | |-- <DueFlashStorage> 1.0.0
| | |-- <Adafruit BusIO> 1.11.6
| | | |-- <Wire> 1.0
| | | |-- <SPI> 1.0
| | |-- <Wire> 1.0
| | |-- <SPI> 1.0
| | |-- <Adafruit LED Backpack Library> 1.3.2+sha.508c0e6
| | |-- <Adafruit GFX Library> 1.11.1
| | | |-- <SPI> 1.0
| | | |-- <Wire> 1.0
| | |-- <BingUI> 0.2
| | | |-- <gd2-lib> 1.3.4
| | | | |-- <SPI> 1.0
| | |-- <AudioI2S> 1.0.1
| | | |-- <SdFat> 1.1.0
| | | | |-- <SPI> 1.0
| | |-- <gd2-lib> 1.3.4
| | | |-- <SPI> 1.0
| |-- <Wire> 1.0
| |-- <SPI> 1.0
| |-- <SPI> 1.0
| |-- <Wire> 1.0
|-- <BingMachine>
| |-- <SdFat> 1.1.0
| | |-- <SPI> 1.0
| |-- <ArduinoMD5>
| | |-- <Wire> 1.0
| | |-- <SPI> 1.0
| |-- <Wire> 1.0
| |-- <SPI> 1.0
| | |-- <SPI> 1.0
| | |-- <Wire> 1.0
| |-- <BingUI> 0.2
| | |-- <gd2-lib> 1.3.4
| | | |-- <SPI> 1.0
| |-- <AudioI2S> 1.0.1
| | |-- <SdFat> 1.1.0
| | | |-- <SPI> 1.0
| |-- <gd2-lib> 1.3.4
| | |-- <SPI> 1.0
|-- <BingUI> 0.2
| |-- <gd2-lib> 1.3.4
| | |-- <SPI> 1.0
|-- <AudioI2S> 1.0.1
| |-- <SdFat> 1.1.0
| | |-- <SPI> 1.0
|-- <gd2-lib> 1.3.4
| |-- <SPI> 1.0
|-- <SdFat> 1.1.0
| |-- <SPI> 1.0
How can the DRV2605 library be dependent on the BingMachine library, that doesn’t look right at all.
Have you added a library.json
in the Adafruit DRV2605 library maybe?
Playing around with the lib_ldf_mode
does not help?
Yes, now that you say it that is weird. I can try installing everything again, maybe i messed up and ended up with that recurrent dependency
Adafruit DRV2605 does not have a library.json
I played around with deep, chain, and their + versions both in GlobalLocal and in BingMachine
There may also be improvements if you upgrade to the latest 6.x core preview version (CLI → pio upgrade --dev
Nope, no use…
Im gonna try with another computer from scratch. Any of ideas of where could i look for more instalation errors?
If i start adding header files installed in .pio
folder into a new include
folder missing header files dissapear but i have to start adding all nested includes in every library.
Can you reproduce the problem with the includes not working more minimally a smaller test project so that I can have a look it? PlatformIO’s LDF should find the dependencies + configure them, putting them in include is a sort of hack
I have wrote the original programmer. If i don’t get a clear answer i can try recreating something
I’ve sent you a github Repo with the essentials. If you want to take a look i would be most grateful. If not it’s okay. The modules are supposed to compile independently but i don’t know how. Maybe it’s a version issue
It was an identation problem. Two spaces for each dependency.
Plus, dependencies of the local library I am using have to go in the platformio.ini that USES the library.
I would appreciate if i could see the documentation where both of these issues are addressed. If they are not, please instruct me on how to write them
Thanks for all the help
