Hi, i’m a new user of platformIO and i have a problem already.
i am trying to create a remoted controlled arduino with some input-output and some readings accessible via web pages.
i am in the early stage of building the things together but i’m already at a stop.
here the source code and then the errors in compiling!
// send the state of the switch to the web browser
void ajaxRequest(EthernetClient client)
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("<br />");
void ledChangeStatus(EthernetClient client)
int state = digitalRead(RED);
Serial.println(state);
if (state == 1) {
digitalWrite(RED, LOW);
client.print("OFF");
else {
digitalWrite(RED, HIGH);
client.print("ON");
#include <Wire.h>
#include <INA226.h>
#include "BlueDot_BME280.h"
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
BlueDot_BME280 bme280 = BlueDot_BME280();
INA226 ina(Wire);
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
EthernetServer server(80);
File webPage;
int RED = 13; //LED to turn on/off
String HTTP_req; // stores the HTTP request
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for debugging
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// initialize SD card
Serial.println("Checking SD card is accessible...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
HTTP_req = "";
//Set LED to output
pinMode(RED, OUTPUT);
bme280.parameter.communication = 0; //Choose communication protocol
bme280.parameter.I2CAddress = 0x76; //Choose I2C Address
bme280.parameter.sensorMode = 0b01; //Choose sensor mode 0b11
bme280.parameter.IIRfilter = 0b100; //Setup for IIR Filter
bme280.parameter.humidOversampling = 0b101; //Setup Humidity Oversampling
bme280.parameter.tempOversampling = 0b101; //Setup Temperature Ovesampling
bme280.parameter.pressOversampling = 0b101; //Setup Pressure Oversampling
bme280.parameter.pressureSeaLevel = 1013.25; //default value of 1013.25 hPa
bme280.parameter.tempOutsideCelsius = 15; //default value of 15°C
//bme280.parameter.tempOutsideFahrenheit = 59; //default value of 59°F
bme280.init();
Wire.begin();
ina.begin();
// Configure INA226
ina.configure(INA226_AVERAGES_4, INA226_BUS_CONV_TIME_2116US, INA226_SHUNT_CONV_TIME_1100US, INA226_MODE_BUS_CONT);
// Calibrate INA226. Rshunt = 0.01 ohm, Max excepted current = 4A
ina.calibrate(0.01, 4);
// Enable Power Over-Limit Alert
ina.enableOverPowerLimitAlert();
ina.setPowerLimit(0.130);
ina.setAlertLatch(true);
void loop()
Serial.print(F("Duration in Seconds:\t\t"));
Serial.println(float(millis())/1000);
Serial.print(F("Temperature in Celsius:\t\t"));
Serial.println(bme280.readTempC());
Serial.print(F("Temperature in Fahrenheit:\t"));
Serial.println(bme280.readTempF());
Serial.print(F("Humidity in %:\t\t\t"));
Serial.println(bme280.readHumidity());
Serial.print(F("Pressure in hPa:\t\t"));
Serial.println(bme280.readPressure());
Serial.print(F("Altitude in Meters:\t\t"));
Serial.println(bme280.readAltitudeMeter());
Serial.print(F("Altitude in Feet:\t\t"));
Serial.println(bme280.readAltitudeFeet());
Serial.println();
Serial.println();
delay(1000);
Serial.print("Bus voltage: ");
Serial.print(ina.readBusVoltage(), 5);
Serial.println(" V");
Serial.print("Bus power: ");
Serial.print(ina.readBusPower(), 5);
Serial.println(" W");
Serial.print("Shunt voltage: ");
Serial.print(ina.readShuntVoltage(), 5);
Serial.print("Shunt current: ");
Serial.print(ina.readShuntCurrent(), 5);
Serial.println(" A");
if (ina.isAlert())
// Latch will be removed here
Serial.println("ALERT");
Serial.println("");
delay(1000);
// listen for incoming clients
EthernetClient client = server.available();
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read(); // read 1 byte (character) from client
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if ( HTTP_req.length() < 80)
HTTP_req += c; // save the HTTP request 1 char at a time
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
if (HTTP_req.indexOf("ajaxrefresh") >= 0 ) {
ajaxRequest(client); //update the analog values
break;
else if (HTTP_req.indexOf("ledstatus") >= 0 ) {
ledChangeStatus(client); //change the LED state
break;
else {
webPage = SD.open("index.htm"); // open web page file
if (webPage) {
while (webPage.available()) {
client.write(webPage.read()); // send web page to client
webPage.close();
break;
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
HTTP_req = "";
Serial.println("client disconnected");
} // end if (client)
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (4.0.0) > Arduino Uno
- framework-arduino-avr @ 5.1.0
Found 9 compatible libraries
|-- INA226Lib @ 1.1.3
| |-- Wire @ 1.0
|-- BlueDot BME280 Library @ 1.0.9
| |-- SPI @ 1.0
| |-- Wire @ 1.0
|-- Ethernet @ 2.0.1
| |-- SPI @ 1.0
|-- SD @ 1.2.4
| |-- SPI @ 1.0
|-- SPI @ 1.0
|-- Wire @ 1.0
Compiling .pio/build/uno/src/main.cpp.o
src/main.cpp:4:18: error: variable or field 'ajaxRequest' declared void
src/main.cpp:4:18: error: 'EthernetClient' was not declared in this scope
src/main.cpp:4:18: note: suggested alternative: 'ethernet_h_'
ethernet_h_
src/main.cpp:16:22: error: variable or field 'ledChangeStatus' declared void
src/main.cpp:16:22: error: 'EthernetClient' was not declared in this scope
src/main.cpp:16:22: note: suggested alternative: 'ethernet_h_'
ethernet_h_
src/main.cpp: In function 'void loop()':
src/main.cpp:187:13: error: 'ajaxRequest' was not declared in this scope
src/main.cpp:191:13: error: 'ledChangeStatus' was not declared in this scope
*** [.pio/build/uno/src/main.cpp.o] Error 1
=============================================== [FAILED] Took 0.63 seconds ===============================================
what can i do to solve the problem of those 2 functions?
Thank you so much
