I am using PlatformIO with the following configuration:
[env:esp_wroom_02]
platform = espressif8266
board = esp_wroom_02
pio platform show espressif8266
gives me:
Package framework-arduinoespressif8266
Type: framework
Requirements: ~2.20402.0
Installed: Yes
Version: 2.20402.4
Original version: 2.4.2
Description: Arduino Wiring-based Framework (ESP8266 Core)
But there are already new versions available: 2.5.0 or 2.6.0-dev.
How to pickup them (I am able to use 2.5.0 in Arduino)?
Probably I got an answer: Using Arduino Framework with Staging version
If there are some useful tips - please let me know…
I have successfully built my project with
platform = https://github.com/platformio/platform-espressif8266.git#feature/stage
option (version=2.6.0-dev), but failed to update FS image:
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp_wroom_02.html
PLATFORM: Espressif 8266 (Stage) > ESP-WROOM-02
HARDWARE: ESP8266 80MHz 80KB RAM (2MB Flash)
Collected 28 compatible libraries
|-- <ESP8266WiFi> 1.0
|-- <ESP8266HTTPClient> 1.2
|-- <cJSON>
|-- <ESP8266_SSD1306> 4.0.0
| |-- <Wire> 1.0
Building SPIFFS image from 'data' directory to .pioenvs\esp_wroom_02\spiffs.bin
*** [.pioenvs\esp_wroom_02\spiffs.bin] Error 148
If I go back to platform = espressif8266
FS image update works well.
Tried to use 2.5.0
version by replacing package.json
file with old one - same FS issue. At the same time I am able to run 2.5.0
version on Arduino platform.
Is where a way to pickup 2.5.0
version (or some particular one) by PlatformIO?
It will probably take a little while for 2.5.0 to make it to platformIO. The stable version only dropped eight days ago, so for now I think it’s a matter of adding your voice to ESP8266 Arduino 2.5 - New Release · Issue #124 · platformio/platform-espressif8266 · GitHub asking for it to be worked on.
We’ve just added support for 2.5.0. Please re-test with the latest upstream version => Espressif 8266 — PlatformIO latest documentation
We plan to publish the final release of deb/platformio this week.
