SideNotes: A âLIBUSB_ERROR_ACCESSâ while initialising the FTDI drove me nuts: Error: libusb_claim_interface() failed with LIBUSB_ERROR_ACCESS Error: unable to open ftdi device with vid 0403, pid 6010, description ââ and serial 'â
There a many useless explanations about loading & unloading Apple & FTDI serial driversâŚ
The solution was to UNISTALL (yes: remove!) the FTDI driver on MacOS 10.13.X (High Sierra)
cd /Library/Extensions sudo rm -r FTDIUSBSerialDriver.kext
I run in the same problem, iâve done exactly as you did, removed the file as root and reboot but i get the same error again. Lost so much time already, does somebody has an idea ?
Debugging does work on my Mac (10.14.4 Mojave) using the information in the original post (although now simply platform = espressif32 is sufficient). Be sure to put jumpers across the four JTAG-enable pin pairs as described in the ESP32-WROVER-KIT Getting Started Guide (https://docs.espressif.com/projects/esp-idf/en/latest/get-started/get-started-wrover-kit.html). Make sure the FTDI vendor-supplied drivers are not installed and just reply on the Apple built-in driver, and look for the correct value in /dev/cu.usbserial-???.
I spent a lot of time trying to get this working because Iâd missed the step about installing the JTAG-enable jumpers and ended up writing a script to prevent mapping of the first FTDI interface to a serial /dev entry. Itâs actually not necessary to use it but in case itâs useful to someone it can be found here: Script to prevent loading of the Apple USB FTDI interface 0 driver on Mac OS X ¡ GitHub
This worked precisely once for me after deleting the FTDI driver, but then never again. Can anyone suggest what I might be doing wrong?
Itâs a WROVER-KIT as delivered but with the four JTAG jumpers connected. It worked the very first time, I could single-step code, but then never have been able to restart the debugger. From a fresh boot, the output is:
Reading symbols from firmware.elfâŚ
done.
PlatformIO Unified Debugger > Redirecting...
PlatformIO: Initializing remote targetâŚ
Open On-Chip Debugger v0.10.0-esp32-20190313 (2019-03-13-09:59)
Licensed under GNU GPL v2
For bug reports, read OpenOCD: Bug Reporting
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Info : ftdi: if you experience problems at higher adapter clocks, try the command âftdi_tdo_sample_edge fallingâ
Info : clock speed 20000 kHz
Error: JTAG scan chain interrogation failed: all zeroes
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anywayâŚ
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
Warn : Bypassing JTAG setup events due to errors
Info : accepting âgdbâ connection from pipe
Error: No symbols for FreeRTOS
Error: Target not examined yet
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use âgdb_memory_map disableâ.
Error: attempted âgdbâ connection rejected
Ignoring packet error, continuingâŚ
warning: unrecognized item âtimeoutâ in âqSupportedâ response
