Yeah. But I argue that having to manually list unreferenced lib libraries under lib_ignore to get your tests to compile is not something we should settle for. It’s a band-aid that’s only needed because of the bug or strange design decision to have tests draw dependencies from src/main (even though that file has nothing to do with running tests).
…Unless I’m missing something, but my experiments showed it working like this (copied from above):
During testing, what gets compiled from
lib/is anything satisfying the logic below.( [is listed under lib_deps] OR [is in the dependency tree of your test code] OR [is in the dependency tree of src/main.cpp] <-- why? ) AND NOT [is listed under lib_ignore]
