ISS Feerick:
This is almost identical to yours. I modified the display fonts.
* Original code written by pollux labs, 2020
* URL: https://gist.github.com/polluxlabs/1ba7824175c5e011565bd61af2fd1c6b
#define USE_OLED
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (-1 if sharing Arduino reset pin or no reset pin)
#define OLED_I2C_ADDR 0x3C // Displays I2C address
#define OLED_ROTATION 0 // 0 = 0, 1 = 90, 2 = 180 or 3 = 270 (degree rotation)
#define NEOPIXEL_PIN D3
#define NUM_OF_NEOPIXELS 12
#define STATUS_LED LED_BUILTIN
#define STATUS_LED_INVERTED true
#include <ESP8266HTTPClient.h>
#include <ESP8266WiFi.h>
#include <ArduinoJson.h>
#include <Adafruit_NeoPixel.h>
#ifdef USE_OLED
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include "Fonts/FreeSansBold9pt7b.h"
#include "Fonts/Org_01.h"
#include <Adafruit_SSD1306.h>
#include <TimeLib.h>
#include <Timezone.h>
#include "secrets.h"
#ifdef USE_OLED
Adafruit_SSD1306 display(128, 64, &Wire, 8);
long riseTime = 0; // Time the ISS will rise for current position
long currentTime = 0; // Current time (UTC)
long flyoverDuration = 0; // Duration of ISS pass for current position
long timeUntilFlyover = 0; // How long it will be until the next flyover
long timeUntilFlyoverComplete = 0; // How long it will be until the current flyover is complete
enum machineStates
WIFI_INIT,
START,
GET_TIME,
GET_NEXT_PASS,
WAIT_FOR_PASS,
PASS_START,
PASSING,
PASS_COMPLETE
enum machineStates currentState = WIFI_INIT;
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUM_OF_NEOPIXELS, NEOPIXEL_PIN, NEO_GRB + NEO_KHZ800);
WiFiClient client;
void success()
pixels.fill(pixels.Color(0, 255, 0));
pixels.show();
delay(500);
pixels.clear();
pixels.show();
void fail()
pixels.fill(pixels.Color(255, 0, 0));
pixels.show();
delay(500);
pixels.clear();
pixels.show();
bool getCurrentTime()
HTTPClient http;
http.begin(client, "http://worldtimeapi.org/api/timezone/America/New_York"); // URL for getting the current time
int httpCode = http.GET();
if (httpCode > 0)
if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY)
{ //Check for the returning code
String payload = http.getString();
const size_t capacity = JSON_OBJECT_SIZE(15) + 550;
DynamicJsonDocument doc(capacity);
DeserializationError error = deserializeJson(doc, payload);
http.end();
if (error)
Serial.print(F("deserializeJson() failed(current time): "));
Serial.println(error.c_str());
return false;
currentTime = doc["unixtime"]; //save current time
return true;
else
Serial.printf("getCurrentTime(): HTTP request failed, server response: %03i\n", httpCode);
return false;
else
Serial.printf("getCurrentTime(): HTTP request failed, reason: %s\n", http.errorToString(httpCode).c_str());
return false;
bool getNextPass()
HTTPClient http;
http.begin(client, "http://api.open-notify.org/iss-pass.json?lat=" + String(37.25) + "&lon=" + String(-121.9) + "&alt=" + String(260.00) + "&n=5"); //URL for API call
if (httpCode > 0)
String payload = http.getString(); //save response
const size_t capacity = JSON_ARRAY_SIZE(5) + 5 * JSON_OBJECT_SIZE(2) + JSON_OBJECT_SIZE(3) + JSON_OBJECT_SIZE(5) + 190;
http.end();
if (error)
Serial.print(F("deserializeJson() failed: "));
return false;
JsonArray response = doc["response"];
flyoverDuration = response[0]["duration"]; // save duration of the next flyover
riseTime = response[0]["risetime"]; // save start time of the next flyover
if (riseTime < currentTime)
{ //If ISS has already passed, take the next flyover
flyoverDuration = response[1]["duration"];
riseTime = response[1]["risetime"];
return true;
else
Serial.printf("getNextPass(): HTTP request failed, server response: %03i\n", httpCode);
return false;
else
Serial.printf("getNextPass(): HTTP request failed, reason: %s\n", http.errorToString(httpCode).c_str());
return false;
void setup()
Serial.begin(9600);
pinMode(STATUS_LED, OUTPUT); //LED Pin
digitalWrite(STATUS_LED, (STATUS_LED_INVERTED == true) ? HIGH : LOW);
pixels.begin();
pixels.setBrightness(100);
pixels.show();
Serial.println("");
Serial.println(F("ISS Flyover Notifier"));
Serial.println("");
/*#ifdef USE_OLED
if (!display.begin(SSD1306_SWITCHCAPVCC, OLED_I2C_ADDR))
Serial.println(F("SSD1306 initalisation failed"));
display.setRotation(OLED_ROTATION);
display.clearDisplay();
void loop()
switch (currentState)
case WIFI_INIT:
WiFi.begin("TP-Link_7C28", "64411811");
Serial.print(F("WiFi Connecting..."));
#ifdef USE_OLED
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(20, 0);
// Display static text
display.print("Connect");
display.setCursor(20, 16);
display.print("to WiFi");
display.display();
int waitTime = 0;
while ((WiFi.status() != WL_CONNECTED) && (waitTime < 300))
Serial.print(".");
digitalWrite(STATUS_LED, !digitalRead(STATUS_LED));
delay(100);
waitTime++;
if (WiFi.status() == WL_CONNECTED)
success();
Serial.println("CONNECTED!");
currentState = START;
else
Serial.println("FAIL!");
Serial.print(F("Device will restart in "));
for (int i = 5; i >= 1; i--)
Serial.print(i);
Serial.print("...");
fail();
delay(500);
ESP.restart();
break;
case START:
currentState = GET_TIME;
else
break;
case GET_TIME:
Serial.println(F("Getting the current time (UTC)..."));
#ifdef USE_OLED
display.println("Get UTC");
display.println("Time");
display.display();
if (!getCurrentTime())
fail();
delay(1000);
else
success();
Serial.print(F("Current time (UTC) = "));
Serial.println(currentTime);
display.println(currentTime);
display.display();
currentState = GET_NEXT_PASS;
break;
case GET_NEXT_PASS:
Serial.println(F("Looking up next ISS flyover time..."));
#ifdef USE_OLED
display.println("Get Next");
display.println("ISS Pass");
display.display();
if (!getNextPass())
fail();
delay(1000);
else
success();
//compute time until rise
timeUntilFlyover = riseTime - currentTime;
Serial.print("Risetime = ");
Serial.println(riseTime);
Serial.print(F("Time until flyover (in seconds): "));
Serial.println(timeUntilFlyover);
uint32_t t = timeUntilFlyover;
int s = t % 60;
t = (t - s) / 60;
int m = t % 60;
t = (t - m) / 60;
int h = t;
Serial.printf("That's %02i hours, %02i minutes and %02i seconds from now\n", h, m, s);
t = flyoverDuration;
s = t % 60;
t = (t - s) / 60;
m = t % 60;
Serial.printf("Estimated pass duration will be %02i minutes and %02i second(s)\n", m, s);
timeUntilFlyoverComplete = flyoverDuration;
currentState = WAIT_FOR_PASS;
break;
case WAIT_FOR_PASS:
if (timeUntilFlyover > 0)
{ // while the ISS isn't overhead
int s = t % 60;
t = (t - s) / 60;
int m = t % 60;
t = (t - m) / 60;
int h = t;
Serial.printf("Next ISS flyover in %02i:%02i:%02i\n", h, m, s);
#ifdef USE_OLED
display.setTextSize(1);
display.setCursor(5, 5);
display.setFont(&Org_01);
display.print("Next flyover:");
display.setTextSize(3);
display.setCursor(5, 25);
display.printf("%02i:%02i:%02i", h, m, s);
display.display();
timeUntilFlyover--;
delay(1000);
else
currentState = PASS_START;
break;
case PASS_START:
//when ISS rises above the horizon
Serial.println(F("ISS overhead!"));
uint32_t t = timeUntilFlyoverComplete;
int s = t % 60;
t = (t - s) / 60;
int m = t % 60;
Serial.printf("Estimated pass duration %02i minutes and %02i second(s)\n", m, s);
currentState = PASSING;
break;
case PASSING:
if (timeUntilFlyoverComplete > 0)
//map remaining flyover time on a color gradient
int colorRed = map(timeUntilFlyoverComplete, 0, flyoverDuration, 200, 0);
int colorBlue = map(timeUntilFlyoverComplete, 0, flyoverDuration, 0, 200);
//show the current color on all LEDs
pixels.fill(pixels.Color(colorRed, 0, colorBlue));
pixels.show();
timeUntilFlyoverComplete--;
int s = t % 60;
t = (t - s) / 60;
int m = t % 60;
Serial.printf("Pass time remaining: %02i minutes and %02i second(s)\n", m, s);
#ifdef USE_OLED
display.setCursor(20, 5);
display.print("Overhead!");
display.setCursor(20, 28);
display.printf("%02i:%02i", m, s);
display.display();
delay(1000);
else
currentState = PASS_COMPLETE;
break;
case PASS_COMPLETE:
//shut down the NeoPixel until next ISS flyover
pixels.clear();
pixels.show();
break;
