Hey,
Today I ran into a problem that seems to have something to do with the PlatformIO compiler. When I try to comile this code using the mbed online IDE it work’s…
The problem is that it does not find the header RangeSensor.h even though it exists in the lib ST_INTERFACES
So here some informations:
System Information:
OS: Windows 10 Pro 1803
Processor: Intel i5-8400
RAM: 16 GB
ARCH: 64 bit
PlatformIO Core: PlatformIO, version 4.0.0a1
PlatformIO IDE: Visual Studio Code 1.6.0
Pip: pip 18.1 from c:\users\user.platformio\penv\lib\site-packages\pip (python 2.7)
VS Code: 1.30.2 (system wide)
platformio.ini
[env:nucleo_f446re]
platform = ststm32
board = nucleo_f446re
framework = mbed
lib_ldf_mode = deep+
lib_deps = https//os.mbed.com/teams/ST/code/VL53L0X/,
https//os.mbed.com/teams/ST/code/ST_INTERFACES/,
https//developer.mbed.org/teams/ST/code/X_NUCLEO_COMMON/
lib_ignore = mbed-os
build_flags = -D PIO_FRAMEWORK_MBED_RTOS_PRESENT
main.cpp
#include <mbed.h>
#include <I2C.h>
#include <VL53L0X.h>
#include <RangeSensor.h>
Serial pc(SERIAL_TX, SERIAL_RX);
int main() {
wait(10);
Output
> Executing task: C:\Users\user.platformio\penv\Scripts\platformio.exe run <
Processing nucleo_f446re (framework: mbed; platform: ststm32; board: nucleo_f446re)
Verbose mode can be enabled via-v, --verbose
option
CONFIGURATION: https//docs.platformio.org/page/boards/ststm32/nucleo_f446re.html
PLATFORM: ST STM32 > ST Nucleo F446RE
HARDWARE: STM32F446RET6 180MHz 128KB RAM (512KB Flash)
DEBUG: CURRENT(stlink) ON-BOARD(stlink) EXTERNAL(blackmagic, jlink)
Library Dependency Finder -> http//bit.ly/configure-pio-ldf
LDF MODES: FINDER(deep+) COMPATIBILITY(soft)
Collected 46 compatible libraries
Scanning dependencies…
|-- #d25c4fa216af
| |-- <X_NUCLEO_COMMON> #21096473f63e
|-- <ST_INTERFACES> #d3c9b33b992c
Compiling .pioenvs\nucleo_f446re\src\main.o
Compiling .pioenvs\nucleo_f446re\libc82\VL53L0X\VL53L0X.o
In file included from src\main.cpp:6:0:
.piolibdeps\VL53L0X/VL53L0X.h:46:10: fatal error: RangeSensor.h: No such file or directory*********************************************************************
* Looking for RangeSensor.h dependency? Check our library registry!
* CLI > platformio lib search “header:RangeSensor.h”
* Web > https//platformio.org/lib/search?query=header:RangeSensor.h
#include “RangeSensor.h”
compilation terminated.
*** [.pioenvs\nucleo_f446re\src\main.o] Error 1
In file included from .piolibdeps\VL53L0X\VL53L0X.cpp:41:0:
.piolibdeps\VL53L0X\VL53L0X.h:46:10: fatal error: RangeSensor.h: No such file or directory*********************************************************************
*********************************************************************#include “RangeSensor.h”
*** [.pioenvs\nucleo_f446re\libc82\VL53L0X\VL53L0X.o] Error 1
==================================================================================================================== [ERROR] Took 6.00 seconds ====================================================================================================================
Der Terminalprozess wurde mit folgendem Exitcode beendet: 1
I removed : from links to post it here. In the original they are contained
