When i write an App for my stm32 Nucleo F446RE and try to upload it it fails in the build state.
Every time I try to compile it or upload it or try “platformio run” in the integrated Powershell it shows this log:
Processing nucleo_f446re (platform: ststm32; board: nucleo_f446re; framework: mbed)
Verbose mode can be enabled via-v, --verbose
option
PLATFORM: ST STM32 > ST Nucleo F446RE
SYSTEM: STM32F446RET6 180MHz 128KB RAM (512KB Flash)
DEBUG: CURRENT(stlink) ON-BOARD(stlink) EXTERNAL(blackmagic, jlink)
Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
Collected 27 compatible libraries
Scanning dependencies…
Compiling .pioenvs\nucleo_f446re\src\main.o
arm-none-eabi-g++: error: CreateProcess: No such file or directory
Compiling .pioenvs\nucleo_f446re\lib778\mbed-os_ID2499\TESTS\events\queue\main.o
Compiling .pioenvs\nucleo_f446re\lib778\mbed-os_ID2499\TESTS\integration\basic\main.o
Compiling .pioenvs\nucleo_f446re\lib778\mbed-os_ID2499\TESTS\mbed_drivers\c_strings\main.o
Compiling .pioenvs\nucleo_f446re\lib778\mbed-os_ID2499\TESTS\mbed_drivers\dev_null\main.o
*** [.pioenvs\nucleo_f446re\src\main.o] Error 1
*** [.pioenvs\nucleo_f446re\lib778\mbed-os_ID2499\TESTS\events\queue\main.o] Error 1Compiling .pioenvs\nucleo_f446re\lib778\mbed-os_ID2499\TESTS\mbed_drivers\echo\main.o*** [.pioenvs\nucleo_f446re\lib778\mbed-os_ID2499\TESTS\integration\basic\main.o] Error 1
*** [.pioenvs\nucleo_f446re\lib778\mbed-os_ID2499\TESTS\mbed_drivers\c_strings\main.o] Error 1
*** [.pioenvs\nucleo_f446re\lib778\mbed-os_ID2499\TESTS\mbed_drivers\dev_null\main.o] Error 1
*** [.pioenvs\nucleo_f446re\lib778\mbed-os_ID2499\TESTS\mbed_drivers\echo\main.o] Error 1
============================================================================================== [ERROR] Took 157.85 seconds ==============================================================================================
I googled the Errors and found nothing…
Windows 10
VS Code 1.28.1 (system wide)
pip 18.0 from c:\users\user.platformio\penv\lib\site-packages\pip (python 2.7)
If you have any Ideas what is causing this problem would be nice if you could help me.
Thank’s in advance
Herobone
