While I’m trying to upload my code, the VScode show me that openocd init failed.
I’m using Windows10
STM32F103ZET6,
openocd 0.10.0,
JLink v8.0
and PlatformIO with VScode.
The openocd is failed to find jlink.cfg and all other .cfg files even if I copy the .cfg files to openocd’s root dir
*Here are the error info while I’m using “openocd -f jlink.cfg”:
PS C:\Users\wjb12\Desktop\PIO> openocd -f jlink.cfg
Open On-Chip Debugger 0.10.0 (2018-11-30)
Licensed under GNU GPL v2
For bug reports, read
embedded:startup.tcl:60: Error: Can’t find jlink.cfg
in procedure ‘script’
at file “embedded:startup.tcl”, line 60
*And here’s the platform error info:
Processing genericSTM32F103ZE (platform: ststm32; board: genericSTM32F103ZE; framework: stm32cube)
Verbose mode can be enabled via -v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: ST STM32 > STM32F103ZE (64k RAM. 512k Flash)
HARDWARE: STM32F103ZET6 72MHz 64KB RAM (512KB Flash)
DEBUG: CURRENT(jlink) EXTERNAL(blackmagic, jlink, stlink)
Warning! Cannot find a linker script for the required board! Firmware will be linked with a default linker script!
Library Dependency Finder → /bit.ly/configure-pio-ldf
Collected 0 compatible libraries
Scanning dependencies…
Checking size .pioenvs\genericSTM32F103ZE\firmware.elf
Memory Usage → /bit.ly/pio-memory-usage
DATA: [ ] 0.0% (used 28 bytes from 65536 bytes)
PROGRAM: [ ] 0.2% (used 844 bytes from 524288 bytes)
Configuring upload protocol…
AVAILABLE: blackmagic, dfu, jlink, serial, stlink
Uploading .pioenvs\genericSTM32F103ZE\firmware.elf
GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00392-gbe9ef0b0 (2018-01-12-15:03)
hla_swd
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 1000 kHz, using 950 kHz
IInfo : clock speed 950 kHz
Error: open failed
in procedure ‘program’
in procedure ‘init’ called at file “embedded:startup.tcl”, line 495
in procedure ‘ocd_bouncer’
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
/I deleted the links in the error info because of th limits/
