Hi guy’s,
I need your help, i have made and compile lot of Marlin config in the past without problem.
But i made new marlin configuration for a friend using an Artillery X2 printer, when i try to compile my Marlin 2.0.9.2 config for this print using an ARTILLERY RUBY motherboard, i have a final error and platformIO try to create a firmware.hex file and not an .bin file i don’t understand why.
Anyone can help my with my issue ?
> Building H:\3D Print\Artillery\Firmware X2\sidewinder-x2-firmware-main\sidewinder-x2-firmware-main\.pio\build\ARTILLERY_RUBY/firmware.hex
> Usage: arm-none-eabi-objcopy [option(s)] in-file [out-file]
> Copies a binary file, possibly transforming it in the process
> The options are:
> -I --input-target <bfdname> Assume input file is in format <bfdname>
> -O --output-target <bfdname> Create an output file in format <bfdname>
> -B --binary-architecture <arch> Set output arch, when input is arch-less
> -F --target <bfdname> Set both input and output format to <bfdname>
> --debugging Convert debugging information, if possible
> -p --preserve-dates Copy modified/access timestamps to the output
> -D --enable-deterministic-archives
> Produce deterministic output when stripping archives
> -U --disable-deterministic-archives
> Disable -D behavior (default)
> -j --only-section <name> Only copy section <name> into the output
> --add-gnu-debuglink=<file> Add section .gnu_debuglink linking to <file>
> -R --remove-section <name> Remove section <name> from the output
> --remove-relocations <name> Remove relocations from section <name>
> -S --strip-all Remove all symbol and relocation information
> -g --strip-debug Remove all debugging symbols & sections
> --strip-dwo Remove all DWO sections
> --strip-unneeded Remove all symbols not needed by relocations
> -N --strip-symbol <name> Do not copy symbol <name>
> --strip-unneeded-symbol <name>
> Do not copy symbol <name> unless needed by
> relocations
> --only-keep-debug Strip everything but the debug information
> --extract-dwo Copy only DWO sections
> --extract-symbol Remove section contents but keep symbols
> -K --keep-symbol <name> Do not strip symbol <name>
> --keep-file-symbols Do not strip file symbol(s)
> --localize-hidden Turn all ELF hidden symbols into locals
> -L --localize-symbol <name> Force symbol <name> to be marked as a local
> --globalize-symbol <name> Force symbol <name> to be marked as a global
> -G --keep-global-symbol <name> Localize all symbols except <name>
> -W --weaken-symbol <name> Force symbol <name> to be marked as a weak
> --weaken Force all global symbols to be marked as weak
> -w --wildcard Permit wildcard in symbol comparison
> -x --discard-all Remove all non-global symbols
> -X --discard-locals Remove any compiler-generated symbols
> -i --interleave[=<number>] Only copy N out of every <number> bytes
> --interleave-width <number> Set N for --interleave
> -b --byte <num> Select byte <num> in every interleaved block
> --gap-fill <val> Fill gaps between sections with <val>
> --pad-to <addr> Pad the last section up to address <addr>
> --set-start <addr> Set the start address to <addr>
> {--change-start|--adjust-start} <incr>
> Add <incr> to the start address
> {--change-addresses|--adjust-vma} <incr>
> Add <incr> to LMA, VMA and start addresses
> {--change-section-address|--adjust-section-vma} <name>{=|+|-}<val>
> Change LMA and VMA of section <name> by <val>
> --change-section-lma <name>{=|+|-}<val>
> Change the LMA of section <name> by <val>
> --change-section-vma <name>{=|+|-}<val>
> Change the VMA of section <name> by <val>
> {--[no-]change-warnings|--[no-]adjust-warnings}
> Warn if a named section does not exist
> --set-section-flags <name>=<flags>
> Set section <name>'s properties to <flags>
> --set-section-alignment <name>=<align>
> Set section <name>'s alignment to <align> bytes
> --add-section <name>=<file> Add section <name> found in <file> to output
> --update-section <name>=<file>
> Update contents of section <name> with
> contents found in <file>
> --dump-section <name>=<file> Dump the contents of section <name> into <file>
> --rename-section <old>=<new>[,<flags>] Rename section <old> to <new>
> --long-section-names {enable|disable|keep}
> Handle long section names in Coff objects.
> --change-leading-char Force output format's leading character style
> --remove-leading-char Remove leading character from global symbols
> --reverse-bytes=<num> Reverse <num> bytes at a time, in output sections with content
> --redefine-sym <old>=<new> Redefine symbol name <old> to <new>
> --redefine-syms <file> --redefine-sym for all symbol pairs
> listed in <file>
> --srec-len <number> Restrict the length of generated Srecords
> --srec-forceS3 Restrict the type of generated Srecords to S3
> --strip-symbols <file> -N for all symbols listed in <file>
> --strip-unneeded-symbols <file>
> --strip-unneeded-symbol for all symbols listed
> in <file>
> --keep-symbols <file> -K for all symbols listed in <file>
> --localize-symbols <file> -L for all symbols listed in <file>
> --globalize-symbols <file> --globalize-symbol for all in <file>
> --keep-global-symbols <file> -G for all symbols listed in <file>
> --weaken-symbols <file> -W for all symbols listed in <file>
> --add-symbol <name>=[<section>:]<value>[,<flags>] Add a symbol
> --alt-machine-code <index> Use the target's <index>'th alternative machine
> --writable-text Mark the output text as writable
> --readonly-text Make the output text write protected
> --pure Mark the output file as demand paged
> --impure Mark the output file as impure
> --prefix-symbols <prefix> Add <prefix> to start of every symbol name
> --prefix-sections <prefix> Add <prefix> to start of every section name
> --prefix-alloc-sections <prefix>
> Add <prefix> to start of every allocatable
> section name
> --file-alignment <num> Set PE file alignment to <num>
> --heap <reserve>[,<commit>] Set PE reserve/commit heap to <reserve>/
> <commit>
> --image-base <address> Set PE image base to <address>
> --section-alignment <num> Set PE section alignment to <num>
> --stack <reserve>[,<commit>] Set PE reserve/commit stack to <reserve>/
> <commit>
> --subsystem <name>[:<version>]
> Set PE subsystem to <name> [& <version>]
> --compress-debug-sections[={none|zlib|zlib-gnu|zlib-gabi}]
> Compress DWARF debug sections using zlib
> --decompress-debug-sections Decompress DWARF debug sections using zlib
> --elf-stt-common=[yes|no] Generate ELF common symbols with STT_COMMON
> type
> --verilog-data-width <number> Specifies data width, in bytes, for verilog output
> -M --merge-notes Remove redundant entries in note sections
> --no-merge-notes Do not attempt to remove redundant notes (default)
> -v --verbose List all object files modified
> @<file> Read options from <file>
> -V --version Display this program's version number
> -h --help Display this output
> --info List object formats & architectures supported
> arm-none-eabi-objcopy: supported targets: elf32-littlearm elf32-littlearm-fdpic elf32-bigarm elf32-bigarm-fdpic elf32-little elf32-big srec symbolsrec verilog tekhex binary ihex plugin
> *** [.pio\build\ARTILLERY_RUBY\firmware.elf] Error 1
> ================================================================= [FAILED] Took 80.86 seconds =================================================================
> Environment Status Duration
> ARTILLERY_RUBY FAILED 00:01:20.858
> ============================================================ 1 failed, 0 succeeded in 00:01:20.858 ============================================================
