Hello
I have error building example blink.ino when using framework 2.0.7
I added the last line of this bloc to the original example platform.ini:
[env:lolin32]
board = lolin32
platform_packages = framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#2.0.7
Then pio run --environment lolin32
Here is my error:
Processing lolin32 (platform: espressif32; framework: arduino; board: lolin32)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/lolin32.html
PLATFORM: Espressif 32 (3.5.0) > WEMOS LOLIN32
- framework-arduinoespressif32 @ 2.0.7+sha.213f976
- tool-esptoolpy @ 1.30100.210531 (3.1.0)
- toolchain-xtensa32 @ 2.50200.97 (5.2.0)
Found 33 compatible libraries
Compiling .pio\build\lolin32\src\Blink.cpp.o
*** [.pio\build\lolin32\bootloader.bin] Source `C:\Users\Public\.platformio\packages\framework-arduinoespressif32@src-96eec79af29abe2be98fb05b0086faed\tools\sdk\esp32\bin\bootloader__40m.elf' not found, needed by target `.pio\build\lolin32\bootloader.bin'.
In file included from src/Blink.cpp:7:0:
C:/Users/Public/.platformio/packages/framework-arduinoespressif32@src-96eec79af29abe2be98fb05b0086faed/cores/esp32/Arduino.h:194:12: error: 'std::round' has not been declared
using std::round;
cc1plus.exe: warning: unrecognized command line option '-Wno-frame-address'
*** [.pio\build\lolin32\src\Blink.cpp.o] Error 1
======================================================================================== [FAILED] Took 6.79 seconds ========================================================================================
Environment Status Duration
lolin32 FAILED 00:00:06.792
================================================================================== 1 failed, 0 succeeded in 00:00:06.792 ==================================================================================
Other env build against 1.0.6 compile fine.
What do I miss ?
Same error with 2.0.6
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)PACKAGES:
- framework-arduinoespressif32 @ 2.0.6+sha.b63f947
*** [.pio\build\lolin32\bootloader.bin] Source `C:\Users\Public\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32\bin\bootloader__40m.elf' not found, needed by target `.pio\build\lolin32\bootloader.bin'.
C:/Users/Public/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:184:12: error: 'std::round' has not been declared
using std::round;
====================================================================== [FAILED] Took 7.76 seconds ======================================================================
lolin32 FAILED 00:00:07.759
================================================================ 1 failed, 0 succeeded in 00:00:07.759 ================================================================
Running Update target fix the problem
esolving lolin32 dependencies...
Platform Manager: Updating espressif32 @ 3.5.0
Platform Manager: Removing espressif32 @ 3.5.0
Platform Manager: espressif32@3.5.0 has been removed!
Platform Manager: Installing platformio/espressif32 @ 6.0.1
Platform Manager: espressif32@6.0.1 has been installed!
Tool Manager: Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Tool Manager: toolchain-xtensa-esp32@8.4.0+2021r2-patch5 has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.40400.0
Tool Manager: tool-esptoolpy@1.40400.0 has been installed!
Yeah that platform code was extremely old. Like Arduino-ESP32 1.0.6 levels.
The PlatformIO VSCode extension (the underlying PlatformIO core to be more precise) will, when the platform has not been previously downlaoded, download the latest available platform version at the moment you create a project for a board of that platform. It will then not auto-update it.
The only exception where you can get an older-than-latest version is when you open a VSCode project that specifically had platform=espressif32@3.5.0
in it, which then became the installed platform-espressif32 version.
