I get this error after an ‘update all’
Failed to activate the platformio-ide package
Unexpected token ...
Hide Stack Trace
SyntaxError: Unexpected token ...
at Module.get_Module._compile (/opt/atom/resources/app/src/native-compile-cache.js:94:52)
at Object.value [as .js] (/opt/atom/resources/app/src/compile-cache.js:240:29)
at Module.load (module.js:488:32)
at tryModuleLoad (module.js:447:12)
at Function.Module._load (module.js:439:3)
at Module.require (file:///opt/atom/resources/app.asar/static/index.js:47:45)
at require (/opt/atom/resources/app/src/native-compile-cache.js:66:33)
at Object.<anonymous> (/home/gerrie/.atom/packages/platformio-ide/node_modules/ws/index.js:3:19)
at Object.<anonymous> (/home/gerrie/.atom/packages/platformio-ide/node_modules/ws/index.js:12:3)
at Module.get_Module._compile (/opt/atom/resources/app/src/native-compile-cache.js:106:36)
at t (/home/gerrie/.atom/packages/platformio-ide/node_modules/platformio-node-helpers/dist/index.js:1:422)
at Object.<anonymous> (/home/gerrie/.atom/packages/platformio-ide/node_modules/platformio-node-helpers/dist/index.js:1:1080)
at Object.<anonymous> (/home/gerrie/.atom/packages/platformio-ide/node_modules/platformio-node-helpers/dist/index.js:3:3)
I also say this was reported and if you search I tried to uninstall atom, reinstall, even Platform IO. I used Atom/Platform I/O for more than a year and have done many projects : How can I fix this :
