Export compiled hex file
You’re right, by default they only build the .bin file. To change this, go into your PlatformIO folder (/home/<user>/.platform or C:\Users\<user>\.platform and open packages/ststm32/builder/main.py and change
    target_firm = env.ElfToBin(join("$BUILD_DIR", "${PROGNAME}"), target_elf)
to
    target_firm = env.ElfToHex(join("$BUILD_DIR", "${PROGNAME}"), target_elf)
and rebuild. The resulting hex file will be in .pioenvs/genericSTM32F103ZE/firmware.hex.
@ivankravets Maybe it’s good feature to be able to change what builder will be used via the platformio.ini?
