Hello
i try to comple a sample-code at the timealarms lib.
if i declare the function
void printDigits(int digits) {
Serial.print(":");
if (digits < 10)
Serial.print('0');
Serial.print(digits);
at the top with
void printDigits(int digits) ;
thats ok… but if i declare this function
void digitalClockDisplay() {
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.println();
with void digitalClockDisplay() ;
then i get an error too
i get some errors like that
src\main.cpp:72:23: error: 'OnceOnly' was not declared in this scope
Alarm.timerOnce(10, OnceOnly); // called once after 10 seconds
src\main.cpp:50:5: warning: unused variable 'stunden' [-Wunused-variable]
int stunden = hour();
i get also an error
with
AlarmId id;
with error-message
src\main.cpp:30:1: error: expected initializer before 'AlarmId'
AlarmId id;
What am I doing wrong?
Best regards
Achim
