Hello guys,
I have an existential question about ESP32 and I would like to share it with you
As far as I understand it is not advisable to use the pins of the ADC2 when working with the WiFi because it causes problems in reading … but what happens if I choose those pins as GPIO or I2C? Do I still have problems using them?
being clearer with the question. Are the pins of the ADC2 forbidden pins that should not be used at all when using WiFi?
Greetings.
As far as I understand it, the conflict is between ADC2 and Wifi. So it should be possible to use the pins for other purposes.
Also see:
https://docs.espressif.com/projects/esp-idf/en/latest/esp32s2/api-reference/peripherals/adc.html#adc-rtc-mode
I agree with @manuelbl assessment, but really if you want a reliable answer for this question, the Espressif forums will connect you with people who build and support this chip;
Hi @maxgerhardt , @manuelbl.
thank you very much for your reply.
Problem only exists with the ADC function.
Normal digital I/O functions work fine - I use all of them
