Can someone confirm if CMake add_custom_target and add_custom_command work with VS-Code and the PlatformIO extension?
I am trying to trigger post-build events in the CMakeList.txt file for components instead of using a Python or Powershell script triggered using the extra_scripts parameter in the pio ini file. However, they are not triggering when compiled with VS-Code and the PlatformIO extension. Thanks in advance.
add_custom_target(
cmp_reg_sync ALL
COMMAND python ${CMAKE_CURRENT_SOURCE_DIR}/stg/pio_lib_sync.py OK
COMMENT "python testing with add_custom_command..."
add_dependencies( ${COMPONENT_LIB} cmp_reg_sync )
add_custom_command(
TARGET ${COMPONENT_LIB}
POST_BUILD
