Hi, im getting this error when trying to compile my scetch.
I have this platform.ini file:
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
ottowinter/ESPAsyncWebServer-esphome@^3.0.0
plerup/EspSoftwareSerial@^8.0.1
bblanchon/ArduinoJson@^6.21.2
mikalhart/TinyGPSPlus@^1.0.3
roboticsbrno/ServoESP32@^1.0.3
extra_scripts =
pre:env-extra.py
board_build.arduino.memory_type = dio_opi ; NEEDED FOR PSRAM
monitor_port = COM13
upload_port = COM13
build_flags = -DCORE_DEBUG_LEVEL=5
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
lib_ldf_mode = deep+
lib_extra_dirs = ~/Documents/Arduino/libraries
can someone help me please with this error message?
Compiling .pio/build/esp32-s3-devkitc-1/FrameworkArduino/wiring_pulse.c.o
Compiling .pio/build/esp32-s3-devkitc-1/FrameworkArduino/wiring_shift.c.o
Archiving .pio/build/esp32-s3-devkitc-1/libFrameworkArduino.a
Indexing .pio/build/esp32-s3-devkitc-1/libFrameworkArduino.a
*** [.pio/build/esp32-s3-devkitc-1/firmware.elf] Implicit dependency `/home/joengelh/.platformio/platforms/espressif32/builder/=' not found, needed by target `.pio/build/esp32-s3-devkitc-1/firmware.elf'.
==================================================== [FAILED] Took 6.24 seconds ====================================================
* The terminal process "platformio 'run'" terminated with exit code: 1.
Thanks a lot
