ESPRESSIF8266 target code not compiling on new PC but does for a Nano
Since building a new PC I can’t build anything but basic code for a ESPRESSIF8266 device, code that use to work does not compile now and I can’t figure out why…
  1. PIO seems to be automatically “including” any header file in the SRC directory so if the existing code specifically includes the file it I get redefinition errors but if I compile the code to a Nano it’s fine, it doesn’t automatically add it
  2. I can’t use the Serial object/class is in a header file anymore. This compiles, uploads and runs (Serial is being used in main.cpp):
1
This does not (Serial is being used in debug.h)
2
But again, if I build the Nano version it all works as expected
This is the PlatformIO.ini
3
[env:d1_mini]
platform = espressif8266
board = d1_mini
upload_protocol = esptool
lib_ldf_mode = chain+
[env:nanoatmega328]
board = nanoatmega328
By calling your file debug.h you have created a conflict with Arduino-ESP8266’s debug.h file. Arduino/debug.h at master · esp8266/Arduino · GitHub. Since the Arduino-AVR core for Nano is different, you do not get that error here. To solve the issue, rename debug.h to something unique.
Also, do not implement functions in a .h file, only put the prototype declarations there. Implement them in a .cpp file in your case.
Bingo! Thanks, that’s worked!
I’m a VB developer so still getting use to how to do things properly!!
