Hi, I am a newbie.
I installed the Espalexa library in PlatformIO but it does not update to the latest version 2.5.0.
This is what it shows in PIO :
Espalexa by Christian Schwinne
Library to control an ESP module with the Alexa voice assistant
Library Dependencies platformio.ini
The PlatformIO Registry is fully compatible with **Semantic Versioning and its "version" scheme <major>.<minor>.<patch>**. You can declare library dependencies in "platformio.ini" configuration file using lib_deps option.
# platformio.ini – project configuration file
[env:my_build_env]
**aircoookie/Espalexa @ 0.0.0-alpha+sha.09981160b5**
