I’ve gone back to some old projects and can not longer build SPIFFS for them.
I get the following cryptic error code
Building SPIFFS image from 'MySONOFF/data' directory to .pioenvs/default/spiffs.bin
*** [.pioenvs/default/spiffs.bin] Error -8
What is weird is that if i create a new project then the tool works fine, even with the same board and settings and even with the data_dir also moved.
I’d like to know the meaning of the error code -8. googlefoo comes up blank.
These projects used to work just fine. I’ve updated and upgraded the project folder.
it does not depend on the contents of the data folders as i created a data dir at the same level of src, and omitted my data_dir flag in platform.ini but it still fails.
I’ve deleted the .pioenvs directory too so it started from scratch, same result.
Thanks
