Hi All,
Let me explain, I did some quick test with a ESP8266 and they worked without problem (I could connect and use it without problem).
But after to increase the code with the real behavior that I want, it stop to work…or well… it doesn’t work properly…
I’m using ESP8266 512k, and I’m using spiff data and C++ code, basically after to push it the wifi is detected but when I try to connect the network disappears (it seems to switch the wifi off), or sometimes it spent a lot of time getting the IP and suddenly it stops and restart the wifi network.
When I upload the code I see this information:
Building .pioenvs/esp01/firmware.bin
Retrieving maximum program size .pioenvs/esp01/firmware.elf
Checking size .pioenvs/esp01/firmware.elf
Memory Usage → Redirecting...
DATA: [==== ] 44.0% (used 36016 bytes from 81920 bytes)
PROGRAM: [======= ] 74.2% (used 322224 bytes from 434160 bytes)
I guess that probably I’m in the limit of the memory usage… I don’t remember very well, but I think that I’ve read something about it.
So do you have any suggestion?, maybe something to debug or profiling the code?
Thanks in advance!!
