This is only my second post so please excuse my obvious(but not to me) error.
There are no errors during compile
the value is correct in module DHT22.cpp
but when it goes to WebPages the content of comfortStatus is blank.
Also can you please tell me how to post blocks of code that look as nice as everybody else’s(I must be missing something again)
Sorry to use up your time.
DHT22.h
#ifndef DHT22_H
#define DHT22_H
#include <DHTesp.h>
#include <Adafruit_BMP280.h>
extern int dhtPin;
extern int pressure_offset;
extern Adafruit_BMP280 bme;
extern float dht_tv, dht_hv, bmp_tv, bmp_pv, bmp_av;
extern float heatIndex;
extern float dewPoint;
extern float cr;
extern String comfortStatus;
void DHT22_Setup();
void DHT22_Get();
DHT22.cpp
#include "DHT22.h"
int dhtPin = D3;
int pressure_offset = 1000;
float heatIndex = 0;
float dewPoint = 0;
float cr = 0;
DHTesp dht;
void DHT22_Setup()
dht.setup(dhtPin, DHTesp::DHT22);
while (!bme.begin())
Serial.println("Could not find a sensor, check wiring!");
void DHT22_Get()
for (int i = 1; i <= 20; i++)
dht_tv = dht_tv + dht.getTemperature();
dht_hv = dht_hv + dht.getHumidity();
bmp_tv = bmp_tv + bme.readTemperature();
bmp_pv = bmp_pv + bme.readPressure() / 100.0F + pressure_offset;
bmp_av = bmp_av + bme.readAltitude(1019.66);
//Serial.println(dht_tv);
if (isnan(dht_tv))
{ // if DHT in error put esp to sleep turn off power to DHT
Serial.println("Going To Sleep Back in 15 Sec");
dht_tv = dht_tv / 20;
dht_hv = dht_hv / 20;
bmp_tv = bmp_tv / 20;
bmp_pv = bmp_pv / 20;
bmp_av = bmp_av / 20;
ComfortState cf;
TempAndHumidity newValues = dht.getTempAndHumidity();
float heatIndex = dht.computeHeatIndex(newValues.temperature, newValues.humidity);
float dewPoint = dht.computeDewPoint(newValues.temperature, newValues.humidity);
float cr = dht.getComfortRatio(cf, newValues.temperature, newValues.humidity);
switch (cf)
case Comfort_OK:
comfortStatus = "Comfort_OK";
break;
case Comfort_TooHot:
comfortStatus = "Comfort_TooHot";
break;
case Comfort_TooCold:
comfortStatus = "Comfort_TooCold";
break;
case Comfort_TooDry:
comfortStatus = "Comfort_TooDry";
break;
case Comfort_TooHumid:
comfortStatus = "Comfort_TooHumid";
break;
case Comfort_HotAndHumid:
comfortStatus = "Comfort_HotAndHumid";
break;
case Comfort_HotAndDry:
comfortStatus = "Comfort_HotAndDry";
break;
case Comfort_ColdAndHumid:
comfortStatus = "Comfort_ColdAndHumid";
break;
case Comfort_ColdAndDry:
comfortStatus = "Comfort_ColdAndDry";
break;
default:
comfortStatus = "Unknown:";
break;
Serial.println("");
Serial.println(dht_hv);
Serial.println(bmp_tv);
Serial.println(bmp_pv);
Serial.println(bmp_av);
Serial.println(comfortStatus);
Serial.println("");
WebPages.cpp
#include "WebPages.h"
#include "Wifi_Setup.h"
#include "Power.h"
#include "TimeSetup.h"
#include "DHT22.h"
///////////////////////////////// HTML BUTTON PRESSED /////////////////////////////////////////////
void Web_Listen()
server.handleClient();
////////////////////////////////// HTML HEADER PAGE ///////////////////////////////////////////////
void Header()
server.sendHeader("Cache-Control", "no-cache, no-store, must-revalidate");
server.sendHeader("Pragma", "no-cache");
server.sendHeader("Connection", "Keep-Alive");
server.sendHeader("Expires", "-1");
server.setContentLength(CONTENT_LENGTH_UNKNOWN);
server.send(200, "text/html", ""); // Empty content inhibits Content-length header
// For each new page you add or remove, make sure there is a menu item to call it or remove it when not used
void Site_Navbar()
webpage += F(" <a href='/homepage'>Home</a>");
//webpage +=F(" <a href='/chart'>Chart</a>");
//webpage +=F(" <a href='/Gauge'>Gauge</a>");
//webpage += F(" <a href='/dht'>DHT Reading</a>");
webpage += F("</div>");
void SendHTML_Content()
server.sendContent(webpage);
webpage = "";
void SendHTML_Stop()
server.sendContent("");
server.client().stop(); // Stop is needed because no content length was sent
void homepagePL()
Header();
//Site_Navbar();
CallTime();
webpage += "<p>This page was displayed on : " + String(Timet) + " Hr</p>";
//homepage_uptime();
homepage();
SendHTML_Content(); // Send footer
SendHTML_Stop();
webpage = "";
void homepage()
webpage += ("<!DOCTYPE html><html>");
webpage += ("<head><meta name=\"viewport\"width=device-width, initial-scale=1\">");
//webpage +=F("<html charset=UTF-8><head><meta http-equiv='refresh' content='60'");
webpage += ("<link rel=\"icon\" href=\"data:,\">");
webpage += ("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
webpage += (".button { background-color: #4CAF50; border: 4px solid #4CAF50;; color: white; padding: 15px 32px; text-align: center; text-decoration: none; display: inline-block; font-size: 16px; margin: 4px 2px; cursor: pointer; }");
webpage += ("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
// Web Page Heading
webpage += ("</style></head>");
webpage += ("<center><h2>Runtime: ");
webpage += (Day);
webpage += (" : ");
webpage += (Hour);
webpage += (" : ");
webpage += (Min);
webpage += (" : ");
webpage += (Sec);
webpage += ("</h2></center>");
webpage += ("<center><h2></h3></center>");
webpage += ("<form>");
webpage += ("<center>");
webpage += ("<html><head><meta http-equiv=\"Content-Language\" content=\"en-us\"><meta http-equiv=\"Content-Type\" content=\"text/html; charset=windows-1252\";>");
webpage += ("<title>Power Moniter 8266</title></head><body><p><b><font face=\"Arial Black\" size=\"6\" color=\"#0000FF\">Power Moniter 8266 </font>");
webpage += ("</b></p>");
webpage += ("<table border=\"4\" width=\"420\" bordercolorlight=\"#000000\" bordercolordark=\"#008000\" height=\"137\">");
webpage += ("<tr><td style=\"border-style: solid; border-width: 1px\" width=\"370\" bgcolor=\"#CC6600\" align=\"center\">");
webpage += ("<b><font face=\"Verdana\" size=\"2\" color=\"#FFFF99\">Device</font></b>");
webpage += ("</td><td style=\"border-style: solid; border-width: 1px\" bgcolor=\"#CC6600\" align=\"center\">");
webpage += ("<b><font face=\"Verdana\" size=\"2\" color=\"#FFFF99\">Voltage</font></b>");
webpage += ("<b><font face=\"Verdana\" size=\"2\" color=\"#FFFF99\">Current</font></b>");
webpage += ("<b><font face=\"Verdana\" size=\"2\" color=\"#FFFF99\">Power</font></td></tr></b>");
webpage += ("<tr><td style=\"border-style: solid; border-width: 1px\" width=\"20% \" align=\"center\">");
webpage += ("Bus Voltage_A ");
webpage += ("</font></a></td><td style=\"border-style: solid; border-width: 1px\" width=\"10%\" align=\"center\">");
webpage += (loadvoltage_A);
webpage += (current_mA_A);
webpage += (power_mW_A);
webpage += ("<tr><td style=\"border-style: solid; border-width: 1px\" width=\"20%\" align=\"center\">");
"Bus Voltage_B ");
webpage += (loadvoltage_B);
webpage += ("</font></a></td><td style=\"border-style: solid; border-width: 1px\" width=\"10%\"align=\"center\">");
webpage += (current_mA_B);
webpage += (power_mW_B);
//webpage +=("<tr><td style=\"border-style: solid; border-width: 1px\" width=\"20%\" align=\"center\">");
webpage += ("<b><font face=\"Verdana\" size=\"2\" color=\"#FFFF99\">Temperature</font></b>");
webpage += ("<b><font face=\"Verdana\" size=\"2\" color=\"#FFFF99\">Humidity</font></b>");
webpage += ("<b><font face=\"Verdana\" size=\"2\" color=\"#FFFF99\">Comfort</font></td></tr></b>");
webpage += ("DHT22 ");
webpage += (dht_tv);
webpage += (dht_hv);
**webpage += ("</font></a></td><td style=\"border-style: solid; border-width: 1px\" width=\"10%\" align=\"center\">");
****webpage += (comfortStatus);
**Serial.println("*************");
**Serial.println(comfortStatus);
****Serial.println("*************");
webpage += ("<b><font face=\"Verdana\" size=\"2\" color=\"#FFFF99\">Altitude</font></b>");
webpage += ("<b><font face=\"Verdana\" size=\"2\" color=\"#FFFF99\">Pressure</font></td></tr></b>");
webpage += ("BMP280 ");
webpage += (bmp_tv);
webpage += (bmp_av);
webpage += (bmp_pv);
webpage += ("</b></font></a></td></tr></table>");
webpage += ("</center></form></body></html>");
void TimeP()
CallTime();
webpage += F(" <p>");
webpage += ("<td><b>" + String(Timet) + "</td>");
webpage += F(" </p>");
void homepage_uptime()
//webpage += "<P class='style2'></p>";
//webpage += "<p class='style2'>";
//webpage += "</p>This is the server home page<br>";
String Uptime = (String(millis() / 1000 / 60 / 60)) + ":";
Uptime += (((millis() / 1000 / 60 % 60) < 10) ? "0" + String(millis() / 1000 / 60 % 60) : String(millis() / 1000 / 60 % 60)) + ":";
Uptime += ((millis() / 1000 % 60) < 10) ? "0" + String(millis() / 1000 % 60) : String(millis() / 1000 % 60);
webpage += "<p>Uptime: " + Uptime + "</p>";
