[esp8266] builder tools CheckUploadSize ignores board_upload.maximum_size override in platformio.ini
:dizzy_face:
The more I dig, the deeper down the rabbit hole I go…
Unbeknownst to me, while the ESP has 4MB of flash, it is only capable of running a 1MB program due to
a hardware limitation in the ESP because it is the max size of code mem that can be mapped from the flash. [1]
My efforts to extend the maximum size in the Memory Usage report are for naught, as the current linker scripts for the ESP8266 correctly report a 1MB-4kB size limit, and on a ESP8266 with 4MB of flash, there’s an unsused 1MB section to be found for either serial/OTA updates.
So ends this session of nerd sniping.
[1]: Investigate breaking the max sketch size limit · Issue #6681 · esp8266/Arduino · GitHub
