[this is the same question as Issue 226 with platformio/platform-espressif8266]
I use platformio 4.3.4 with the arduino framework. In various sketches that I looked at, it is implied that loop()
is called within an endless loop so exiting the function is not a big deal, it will be called again. I even found posts around esp8266 and loop implying that you can not run too much functionality within a single loop as this may affect WiFi and other functionality.
BUT in the platformio version of Arduino.h (from framework-arduinoespressif8266 @ 3.20704.0), the loop()
function is marked as [[noreturn]]
and lo and behold, if my code actually exits loop(), the board crashes with a stack trace.
This is even more confusing, as in the official arduino repo (Arduino/Arduino.h at master · esp8266/Arduino · GitHub), it is not. The platformio framework claims that it is based on 2.7.4 (Update Arduino core to 2.7.4 · platformio/platform-espressif8266@fbbe4e2 · GitHub).
Diffing the cores/esp8266 tree from this repo with the locally installed ~/.platformio/packages/framework-arduinoespressif8266/cores/esp8266 literally shows this as the only significant difference between the arduino repo and what I see locally:
diff -urb Arduino/cores/esp8266/Arduino.h /home/henning/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/Arduino.h
--- Arduino/cores/esp8266/Arduino.h 2020-08-17 14:09:18.245135688 -0700
+++ /home/henning/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/Arduino.h 2020-08-14 09:47:57.771492095 -0700
@@ -201,7 +201,7 @@
void preinit(void);
void setup(void);
-void loop(void);
+[[noreturn]] void loop(void);
void yield(void);
diff -urb Arduino/cores/esp8266/core_esp8266_main.cpp /home/henning/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/core_esp8266_main.cpp
--- Arduino/cores/esp8266/core_esp8266_main.cpp 2020-08-17 14:09:18.246135675 -0700
+++ /home/henning/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/core_esp8266_main.cpp 2020-08-14 09:47:57.786491890 -0700
@@ -40,7 +40,8 @@
#define LOOP_QUEUE_SIZE 1
extern "C" void call_user_start();
-extern void loop();
+[[noreturn]] extern void loop();
extern void setup();
extern void (*__init_array_start)(void);
extern void (*__init_array_end)(void);
So my guess is that there is a reason for this. But I don’t understand it. This seems to be platformio specific and it requires me to rewrite code that works on non-platformio arduino code. What is more confusing, I don’t seem to be able to pinpoint the platce where this change is made nor am I able to find documentation as to why this is changed in platformio.
Can you show:
platformio.ini
- the full build log
On my PlatformIO installation, loop()
does not have the [[noreturn]]
annotation.
Can you additionally check that you have just a single framework-arduinoespressif8266
directory in /home/henning/.platformio/packages
, i.e. no other directory like framework-arduinoespressif8266@83de8812a
I nuked my local .platformio today and reinstalled “the official way” (with get-platformio.py) and now the Arduino.h file is fine. Very weird. Before, I always installed with “pip install -U platformio” into a virtualenv.
However, at this point I can no longer reproduce this. I have a backup of the old install and the only source difference between that tree and the current (correct) tree is that one line. And if I now compile code that reliably crashed my ESP-01 board by exiting loop(), the same code works just fine.
This is incredibly weird. I checked another laptop with an older platformio installation and it also had the [[noreturn]] in Arduino.h (with 2.7.1 release). I ran pio update/upgrade on the laptop and it also disappeared.
Short of Gremlins, I have no idea how I got into that state. I did not do anything out of the ordinary (with the exception of using pip install instead of the get-platformio script).
Anyway, all seems to work for me now. Sorry for the noise. I may come back if I find a way to reliably reproduce the problem.
Oh, to your questions:
- I only have one version of the framework-arduinoespressif8266 (2.6.2)
721@3.1.6 ; TaskScheduler
1358@0.2.1 ; PCF8574
576@1.1.4 ; LiquidCrystal_I2C
[env:esp01_1m]
platform = espressif8266
board = esp01_1m
❯ pio run
Processing esp01_1m (platform: espressif8266; board: esp01_1m; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp01_1m.html
PLATFORM: Espressif 8266 2.6.2 > Espressif Generic ESP8266 ESP-01 1M
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
LibraryManager: Installing id=721 @ 3.1.6
Using cache: /home/henning/.platformio/.cache/6c/7de79d5f71cd8e14e6f7e8deb3aab46c
TaskScheduler @ 3.1.6 has been successfully installed!
LibraryManager: Installing id=1358 @ 0.2.1
Using cache: /home/henning/.platformio/.cache/7c/712aabd5dac77462f54e8c30f51cfa7c
PCF8574 @ 0.2.1 has been successfully installed!
LibraryManager: Installing id=576 @ 1.1.4
Using cache: /home/henning/.platformio/.cache/9c/617697dd58dade4d7a09b2ed2638309c
LiquidCrystal_I2C @ 1.1.4 has been successfully installed!
Found 32 compatible libraries
|-- <ESP8266WiFi> 1.0
|-- <TaskScheduler> 3.1.6
|-- <LiquidCrystal_I2C> 1.1.4
| |-- <Wire> 1.0
|-- <PCF8574> 0.2.1
| |-- <Wire> 1.0
|-- <Wire> 1.0
Archiving .pio/build/esp01_1m/libFrameworkArduino.a
Indexing .pio/build/esp01_1m/libFrameworkArduino.a
Linking .pio/build/esp01_1m/firmware.elf
Building .pio/build/esp01_1m/firmware.bin
Retrieving maximum program size .pio/build/esp01_1m/firmware.elf
Checking size .pio/build/esp01_1m/firmware.elf
RAM: [=== ] 33.8% (used 27676 bytes from 81920 bytes)
Flash: [==== ] 35.3% (used 268880 bytes from 761840 bytes)
Creating BIN file ".pio/build/esp01_1m/firmware.bin" using "/home/henning/.platformio/packages/framework-arduinoespressif8266/bootloaders/eboot/eboot.elf" and ".pio/build/esp01_1m/firmware.elf"
I actually figured it out.
Maybe I should have led with this: I am using CLion. This is the bug: https://youtrack.jetbrains.com/issue/CPP-21848
