Hi community…
I have tried to import in platformio the folowing repo in github…
When I try to compile I have 2 issues…
The first one regarding the unknown presence of a define
Then when I set it manually I have issues during the linking stage…
Can you try to do that too?
You don’t need the board for compiling…
Thanks a lot for your huge help
When the project was created in April 2021, the platform-espressif32 version was 3.2.0. Compiling with a higher platform version uses a different ESP-IDF and possibly creates these incompatbilities. Try replacing
with
platform = espressif32@3.2.0
Using the platformio.ini
[env]
build_unflags=-Werror=all
[env:esp32cam]
board = esp32cam
framework = espidf
board_build.partitions = partitions.csv
esp32-camera@1.0.0
works completely for me with 0 code changes. Both older platform + older camera library must be used.
Checking size .pio\build\esp32cam\firmware.elf
RAM: [= ] 12.6% (used 41384 bytes from 327680 bytes)
Flash: [====== ] 63.3% (used 830280 bytes from 1310720 bytes)
Building .pio\build\esp32cam\firmware.bin
Thanks Max… I will try this evening and I will try to run it in the mcu… Thanks a lot
