I am new to ESP32. I notice that each time I build, even with no code change, the command uninstalls and reinstalls some modules. Is it normal?
framework = espidf
Processing esp32dev (platform: espressif32; board: esp32dev; framework: espidf)
----------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (5.1.1) > Espressif ESP32 Dev Module
- framework-espidf @ 3.40401.0 (4.4.1)
- tool-cmake @ 3.16.4
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
Warning! Couldn't extract the list of installed Python packages.
Installing ESP-IDF's Python dependencies
Collecting cryptography<35.0.0,>=2.1.4
Using cached cryptography-3.4.8-cp36-abi3-win_amd64.whl (1.6 MB)
Collecting future>=0.15.2
Using cached future-0.18.2-py3-none-any.whl
Collecting pyparsing<2.4.0,>=2.0.3
Using cached pyparsing-2.3.1-py2.py3-none-any.whl (61 kB)
Collecting kconfiglib==13.7.1
Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
Collecting cffi>=1.12
Using cached cffi-1.15.1-cp39-cp39-win_amd64.whl (179 kB)
Collecting pycparser
Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
Installing collected packages: pyparsing, pycparser, kconfiglib, future, cffi, cryptography
Attempting uninstall: pyparsing
Found existing installation: pyparsing 2.3.1
Uninstalling pyparsing-2.3.1:
Successfully uninstalled pyparsing-2.3.1
Attempting uninstall: pycparser
Found existing installation: pycparser 2.21
Uninstalling pycparser-2.21:
Successfully uninstalled pycparser-2.21
Attempting uninstall: kconfiglib
Found existing installation: kconfiglib 13.7.1
Uninstalling kconfiglib-13.7.1:
Successfully uninstalled kconfiglib-13.7.1
Attempting uninstall: future
Found existing installation: future 0.18.2
Uninstalling future-0.18.2:
Successfully uninstalled future-0.18.2
Attempting uninstall: cffi
Found existing installation: cffi 1.15.1
Uninstalling cffi-1.15.1:
Successfully uninstalled cffi-1.15.1
Attempting uninstall: cryptography
Found existing installation: cryptography 3.4.8
Uninstalling cryptography-3.4.8:
Successfully uninstalled cryptography-3.4.8
Successfully installed cffi-1.15.1 cryptography-3.4.8 future-0.18.2 kconfiglib-13.7.1 pycparser-2.21 pyparsing-2.3.1
[notice] A new release of pip available: 22.1.2 -> 22.2.2
[notice] To update, run: python.exe -m pip install --upgrade pip
Found 0 compatible libraries
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [ ] 3.5% (used 11312 bytes from 327680 bytes)
Flash: [== ] 16.1% (used 168793 bytes from 1048576 bytes)
=========================================================== [SUCCESS] Took 42.57 seconds =========================================================== * Terminal will be reused by tasks, press any key to close it.
