Hey guys,
I’m having a really tough time with this one. I’m running VSCode with Platformio for an ESP32 using ESP-IDF environment. I’ve got a TIAO JTAG running, and with a tiny bit of coaxing, I’ve got GDB running on it. However, not smoothly.
From the CLI, I can run pio debug and pio debug --interface=gdb -x .pioinit and it loads fine. However, running debug in VSCode gets me an internal error. Seems that VSCode is trying to run a few gdb commands that my gdb doesn’t like. Any ideas on where to go from here?
eading symbols from /Users/w/Documents/PlatformIO/Projects/ESP32_Second/.pioenvs/esp32doit-devkit-v1/firmware.elf...
done.
PlatformIO Unified Debugger > http://bit.ly/pio-debug
Open On-Chip Debugger 0.10.0-dev (2018-07-24-09:39)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
cpu0: Current bits set: BreakIn BreakOut RunStallIn
cpu1: Current bits set: BreakIn BreakOut RunStallIn
esp32: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
esp32: Core was reset (pwrstat=0x5F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core was reset (pwrstat=0x1F, after clear 0x0F).
/Volumes/build/idf/crosstool-NG/.build/src/gdb-7.10/gdb/findvar.c:290: internal-error: struct value *value_of_register_lazy(struct frame_info *, int): Assertion `frame_id_p (get_frame_id (frame))' failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
