I had hardware where I used the ESP32 DEV Kit1(Wroom), the prototype was changed to use a “Wrover” and I use the DEV KitV4 programming schematic on my new PCB. I plugged it into my notebook and the CP2102N register and I can program the first 4 PCBs without a problem. My colleague however uses windows10 and it just doesn’t want to upload. Because we use dual boot I also rebooted in Linux (Ubuntu) and to my surprise, it also did not want to “upload”. Both use esptool.py v3.1. I tried in windows to delete the pytool directory, updated all libs, tools ext to the latest version, and even reinstall visual studio code, to no avail. I tried to lower the upload speed etc,
Ini file:
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
upload_speed = 460800
upload_port = /dev/ttyUSB0
PC Error message
RAM: [= ] 12.0% (used 39308 bytes from 327680 bytes)
Flash: [====== ] 55.2% (used 723950 bytes from 1310720 bytes)
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Use manually specified: /dev/ttyUSB0
Uploading .pio/build/esp32doit-devkit-v1/firmware.bin
esptool.py v3.1
Serial port /dev/ttyUSB0
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
Notebook OK
Retrieving maximum program size .pio/build/esp32doit-devkit-v1/firmware.elf
Checking size .pio/build/esp32doit-devkit-v1/firmware.elf
Flash: [====== ] 55.2% (used 723986 bytes from 1310720 bytes)
esptool.py v3.1
Connecting....
Chip is ESP32-D0WD (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 84:0d:8e:d2:8d:4c
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x000c0fff...
Compressed 17104 bytes to 11191...
Writing at 0x00001000... (100 %)
Wrote 17104 bytes (11191 compressed) at 0x00001000 in 0.5 seconds (effective 256.6 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 128...
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.1 seconds (effective 393.1 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 569.7 kbit/s)...
Compressed 724096 bytes to 441399...
Writing at 0x00010000... (3 %)
Writing at 0x0001ae8e... (7 %)
Writing at 0x00028444... (11 %)
Writing at 0x00035722... (14 %)
Writing at 0x0003b3ef... (18 %)
Writing at 0x00040f7f... (22 %)
Writing at 0x000465fe... (25 %)
Writing at 0x0004bdd2... (29 %)
Writing at 0x00050e63... (33 %)
Writing at 0x000563a8... (37 %)
Writing at 0x0005b609... (40 %)
Writing at 0x00060c75... (44 %)
Writing at 0x00067bd8... (48 %)
Writing at 0x00070356... (51 %)
Writing at 0x00075ac3... (55 %)
Writing at 0x0007b28e... (59 %)
Writing at 0x000808f2... (62 %)
Writing at 0x00085b82... (66 %)
Writing at 0x0008b590... (70 %)
Writing at 0x000915bd... (74 %)
Writing at 0x00097122... (77 %)
Writing at 0x0009d255... (81 %)
Writing at 0x000a2d6c... (85 %)
Writing at 0x000a8c05... (88 %)
Writing at 0x000aef2a... (92 %)
Writing at 0x000b4d8f... (96 %)
Writing at 0x000baf6f... (100 %)
Wrote 724096 bytes (441399 compressed) at 0x00010000 in 10.2 seconds (effective 565.9 kbit/s)...
Leaving...
Hard resetting via RTS pin...
How can I get more verbose upload information, too scared to touch the working notebook? Something is different
