I am using a ESP32 chip with 16 Mb of memory (I forgot the name of the chip), with a modified Esp 32 board file and partition file.
PLATFORM: Espressif 32 > Espressif ESP32 Dev Module 16 MB v2
SYSTEM: ESP32 240MHz 512KB RAM (3.19MB Flash)
Converting sim5360test.ino
Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
LDF MODES: FINDER(deep) COMPATIBILITY(soft)
Collected 20 compatible libraries
Scanning dependencies…
|-- v2.0.0
|-- v1.1
| |-- v1.0
| |-- v1.0
Compiling .pioenvs/esp32dev/src/sim5360test.ino.cpp.o
Checking size .pioenvs/esp32dev/firmware.elf
Memory Usage → Redirecting...
DATA: [= ] 10.4% (used 54312 bytes from 524288 bytes)
PROGRAM: [= ] 5.8% (used 194953 bytes from 3342336 bytes)
But when I call esp_get_free_heap_size() at the begin of the program it returns:
219876
And esp_get_free_heap_size() returns:
Heap summary for capabilities 0x00000001:
At 0x3ffe0440 len 15296 free 15248 allocated 0 min_free 15248
largest_free_block 15248 alloc_blocks 0 free_blocks 1 total_blocks 1
At 0x3ffe4350 len 113840 free 113792 allocated 0 min_free 113792
largest_free_block 113792 alloc_blocks 0 free_blocks 1 total_blocks 1
At 0x40089b24 len 91356 free 91308 allocated 0 min_free 91308
largest_free_block 91308 alloc_blocks 0 free_blocks 1 total_blocks 1
Totals:
free 220348 allocated 0 min_free 220348 largest_free_block 113792
I there believe that I am not accessing all of the 524288 bytes I allocated to the ram.
Why is this the case and what can I do to fix this?
Thank you for your time in advance.
