Now I get
> Executing task: C:\Users\donvu.platformio\penv\Scripts\platformio.exe run --target upload <
Processing esp32dev (platform: espressif32; framework: arduino; board: esp32dev)
PackageManager: Installing tool-mkspiffs @ ~2.230.0
tool-mkspiffs @ 2.230.0 has been successfully installed!
Verbose mode can be enabled via -v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 1.12.4 > Espressif ESP32 Dev Module
Converting WiFiScan.ino
Found 26 compatible libraries
Scanning dependencies…
|-- 1.0
Compiling .pio\build\esp32dev\src\WiFiScan.ino.cpp.o
Compiling .pio\build\esp32dev\lib4cf\WiFi\ETH.cpp.o
Compiling .pio\build\esp32dev\lib4cf\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32dev\lib4cf\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp32dev\lib4cf\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp32dev\lib4cf\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32dev\lib4cf\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp32dev\lib4cf\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp32dev\lib4cf\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp32dev\lib4cf\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp32dev\lib4cf\WiFi\WiFiUdp.cpp.o
Archiving .pio\build\esp32dev\lib4cf\libWiFi.a
Linking .pio\build\esp32dev\firmware.elf
Building .pio\build\esp32dev\firmware.bin
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [= ] 11.8% (used 38696 bytes from 327680 bytes)
Flash: [===== ] 47.7% (used 625406 bytes from 1310720 bytes)
esptool.py v2.6
Configuring upload protocol…
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port…
Error: Please specify upload_port
for environment or use global --upload-port
option.
For some development platforms it can be a USB flash drive (i.e. /media//)
*** [upload] Explicit exit, status 1
================================================================================================== [FAILED] Took 8.03 seconds ==================================================================================================
Processing esp wrover kit (platform: espressif32; framework: arduino; board: esp-wrover-kit)
option
PLATFORM: Espressif 32 1.12.4 > Espressif ESP-WROVER-KIT
DEBUG: Current (ftdi) On-board (ftdi) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
|-- 1.0
Compiling .pio\build\esp wrover kit\src\WiFiScan.ino.cpp.o
Generating partitions .pio\build\esp wrover kit\partitions.bin
Compiling .pio\build\esp wrover kit\lib4cf\WiFi\ETH.cpp.o
Compiling .pio\build\esp wrover kit\lib4cf\WiFi\WiFi.cpp.o
Compiling .pio\build\esp wrover kit\lib4cf\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp wrover kit\lib4cf\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp wrover kit\lib4cf\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp wrover kit\lib4cf\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp wrover kit\lib4cf\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp wrover kit\lib4cf\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp wrover kit\lib4cf\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp wrover kit\lib4cf\WiFi\WiFiUdp.cpp.o
Archiving .pio\build\esp wrover kit\libFrameworkArduinoVariant.a
Compiling .pio\build\esp wrover kit\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\WMath.cpp.o
Archiving .pio\build\esp wrover kit\lib4cf\libWiFi.a
Compiling .pio\build\esp wrover kit\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\esp wrover kit\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp wrover kit\libFrameworkArduino.a
Linking .pio\build\esp wrover kit\firmware.elf
Building .pio\build\esp wrover kit\firmware.bin
Retrieving maximum program size .pio\build\esp wrover kit\firmware.elf
Checking size .pio\build\esp wrover kit\firmware.elf
esptool.py v2.6
AVAILABLE: esp-prog, espota, esptool, ftdi, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
option.
================================================================================================== [FAILED] Took 10.69 seconds ==================================================================================================
Processing espea32 (platform: espressif32; framework: arduino; board: espea32)
option
PLATFORM: Espressif 32 1.12.4 > April Brother ESPea32
|-- 1.0
Compiling .pio\build\espea32\src\WiFiScan.ino.cpp.o
Generating partitions .pio\build\espea32\partitions.bin
Compiling .pio\build\espea32\lib4cf\WiFi\ETH.cpp.o
Compiling .pio\build\espea32\lib4cf\WiFi\WiFi.cpp.o
Compiling .pio\build\espea32\lib4cf\WiFi\WiFiAP.cpp.o
Compiling .pio\build\espea32\lib4cf\WiFi\WiFiClient.cpp.o
Compiling .pio\build\espea32\lib4cf\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\espea32\lib4cf\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\espea32\lib4cf\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\espea32\lib4cf\WiFi\WiFiScan.cpp.o
Compiling .pio\build\espea32\lib4cf\WiFi\WiFiServer.cpp.o
Compiling .pio\build\espea32\lib4cf\WiFi\WiFiUdp.cpp.o
Archiving .pio\build\espea32\libFrameworkArduinoVariant.a
Compiling .pio\build\espea32\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\Print.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\Stream.cpp.o
Archiving .pio\build\espea32\lib4cf\libWiFi.a
Compiling .pio\build\espea32\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\WString.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\base64.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\espea32\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\espea32\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\espea32\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\espea32\FrameworkArduino\main.cpp.o
Compiling .pio\build\espea32\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\espea32\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\espea32\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\espea32\libFrameworkArduino.a
Linking .pio\build\espea32\firmware.elf
Building .pio\build\espea32\firmware.bin
Retrieving maximum program size .pio\build\espea32\firmware.elf
Checking size .pio\build\espea32\firmware.elf
esptool.py v2.6
option.
================================================================================================== [FAILED] Took 11.49 seconds ==================================================================================================
Processing esp320 (platform: espressif32; framework: arduino; board: esp320)
option
PLATFORM: Espressif 32 1.12.4 > Electronic SweetPeas ESP320
|-- 1.0
Compiling .pio\build\esp320\src\WiFiScan.ino.cpp.o
Generating partitions .pio\build\esp320\partitions.bin
Compiling .pio\build\esp320\lib4cf\WiFi\ETH.cpp.o
Compiling .pio\build\esp320\lib4cf\WiFi\WiFi.cpp.o
Compiling .pio\build\esp320\lib4cf\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp320\lib4cf\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp320\lib4cf\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp320\lib4cf\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp320\lib4cf\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp320\lib4cf\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp320\lib4cf\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp320\lib4cf\WiFi\WiFiUdp.cpp.o
Archiving .pio\build\esp320\libFrameworkArduinoVariant.a
Compiling .pio\build\esp320\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\Print.cpp.o
Archiving .pio\build\esp320\lib4cf\libWiFi.a
Compiling .pio\build\esp320\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp320\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\esp320\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp320\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\esp320\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp320\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\esp320\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\esp320\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp320\libFrameworkArduino.a
Linking .pio\build\esp320\firmware.elf
Building .pio\build\esp320\firmware.bin
Retrieving maximum program size .pio\build\esp320\firmware.elf
Checking size .pio\build\esp320\firmware.elf
esptool.py v2.6
option.
================================================================================================== [FAILED] Took 11.35 seconds ==================================================================================================
Environment Status Duration
esp32dev FAILED 00:00:08.032
esp wrover kit FAILED 00:00:10.687
espea32 FAILED 00:00:11.493
esp320 FAILED 00:00:11.354
============================================================================================= 4 failed, 0 succeeded in 00:00:41.566 =============================================================================================
The terminal process “C:\Users\donvu.platformio\penv\Scripts\platformio.exe ‘run’, ‘–target’, ‘upload’” terminated with exit code: 1.
