Hi All,
When I want to upload my Project using JTAG on my ESP32 I recieve the following Error:
** Programming Started **
auto erase enabled
Error: Invalid command argument
image.base_address option value ('ramework-arduinoespressif32') is not valid
embedded:startup.tcl:454: Error: ** Programming Failed **
in procedure 'program_esp32'
in procedure 'program_error' called at file "C:\Users\Michael\.platformio\packages\tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 152
at file "embedded:startup.tcl", line 454
*** [upload] Error 1
It seems this hould have been fixed some time ago:
opened 02:42AM - 08 Nov 18 UTC
closed 11:00AM - 23 Nov 18 UTC
I am using ESP-Prog and trying to upload a simple sketch to `esp32doit-… devkit-v1`. I running into similar issues found in [this thread](https://community.platformio.org/t/esp32-pio-unified-debugger/4541) .
I get the following error:
DATA: [ ] 4.2% (used 13884 bytes from 327680 bytes)
PROGRAM: [= ] 13.6% (used 178016 bytes from 1310720 bytes)
AVAILABLE: esp-prog, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esp-prog
Uploading .pioenvs\esp32doit-devkit-v1\firmware.bin
Open On-Chip Debugger 0.10.0-dev (2018-11-05-04:10)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
esp32 interrupt mask on
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core 0 was reset (pwrstat=0x1F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x4009171A (active) APP_CPU: PC=0x40000400
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 33 KB
Info : Flash mapping 1: 0x20018 -> 0x400d0018, 90 KB
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
wrote 180224 bytes from file .pioenvs\esp32doit-devkit-v1\firmware.bin in 2.804591s (62.754 KiB/s)
** Programming Finished **
** Verify Started **
read 178160 bytes from file .pioenvs\esp32doit-devkit-v1\firmware.bin and flash bank 0 at offset 0x00010000 in 0.893627s (194.695 KiB/s)
contents match
** Verified OK **
auto erase enabled
in procedure 'program_error' called at file "C:\Users\mazeb\.platformio\packages\tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 152
I noticed `image.base_address option value ('ramework-arduinoespressif32') is not valid` has a incorrect name. It looks like people [ran into this issue back on July 20th](https://community.platformio.org/t/esp32-pio-unified-debugger/4541/12) and was fixed. However, it looks like its back and I couldn't find the specific fix/commit that addresses this issue.
I am currently using the following:
PS C:\Users\mazeb\Documents\PlatformIO\Projects\Test1> platformio update
Updating tool-scons @ 2.20501.4 [Up-to-date]
Updating tool-unity @ 1.20403.0 [Up-to-date]
Updating contrib-pysite @ 0.3.2 [Up-to-date]
Updating contrib-piohome @ 1.0.6 [Up-to-date]
Updating tool-pioplus @ 1.5.2 [Up-to-date]
Platform Espressif 32
Updating espressif32 @ 1.5.0 [Up-to-date]
Updating toolchain-xtensa32 @ 2.50200.80 [Up-to-date]
Updating tool-openocd-esp32 @ 1.1000.20181105[Up-to-date]
Updating tool-mkspiffs @ 2.230.0 [Up-to-date]
Updating framework-arduinoespressif32 @ 2.10000.0 [Up-to-date]
Updating tool-espotapy @ 1.1.2 [Up-to-date]
Updating tool-esptoolpy @ 1.20500.0 [Up-to-date]
Library Manager
Updating FreeRTOS_ARM @ 5d410b29e6 [Up-to-date]
If this is not a bug, please close this issue and advise how to overcome this roadblock.
Thanks
So I did the dev-uprade, cleanded the project and tried again withou any success.
I am using the following tools/settings:
[env:nodemcu-32s]
board = nodemcu-32s
debug_tool = olimex-arm-usb-ocd-h
upload_protocol = olimex-arm-usb-ocd-h
What can I do to thix this? Is this an error or an layer-8 problem on my side?
Thanks a lot and BR
Michael
Could you try the latest upstream version Espressif 32 — PlatformIO latest documentation ?
Does it work?
