esp32 s3 problem
Hi! I have a strange ESP32-S3 serial problem and I’m trying to find the actual cause.
Board: ESP32-S3-DevKitC-1, 8 MB PSRAM
OS: macOS Sequoia 15.7.7, Intel MacBook Pro
IDE/build system: PlatformIO + Arduino
PlatformIO:
  • Espressif32 platform: 7.0.1
  • Arduino framework: 3.20017.241212+sha.dcc1105b
  • esptool works normally
The board has two USB-C ports.
USB port 1 (the ordinary USB port on my board):
/dev/cu.usbmodem14301
VID:PID=303A:1001
Description: USB JTAG/serial debug unit
This port can flash firmware successfully.
Example upload result:
Chip is ESP32-S3 (QFN56) (revision v0.2)
Features: WiFi, BLE, Embedded PSRAM 8MB (AP_3v3)
USB mode: USB-Serial/JTAG
Hash of data verified.
Hard resetting via RTS pin...
SUCCESS
However, after flashing, PlatformIO Serial Monitor is completely empty:
pio device monitor --port /dev/cu.usbmodem14301 -b 115200
No Serial.println() output at all.
If I physically press RESET while the monitor is open, I sometimes get:
Disconnected (read failed: [Errno 6] Device not configured)
Reconnecting to /dev/cu.usbmodem14301 . Connected!
After reconnecting, it is still completely blank.
Important test
I wanted to make sure the ESP32-S3 itself is actually running the firmware, so I removed Serial, SD, TFT, etc. and tested only the onboard/addressable RGB LED on GPIO48.
The test code is:
#include <Adafruit_NeoPixel.h>
#define RGB_PIN 48
Adafruit_NeoPixel rgb(1, RGB_PIN, NEO_GRB + NEO_KHZ800);
    rgb.begin();
    rgb.setPixelColor(0, 255, 0, 0);
    rgb.show();
    delay(500);
    rgb.setPixelColor(0, 0, 255, 0);
    rgb.show();
    delay(500);
    rgb.setPixelColor(0, 0, 0, 255);
    rgb.show();
    delay(500);
    rgb.clear();
    rgb.show();
    delay(500);
The RGB works perfectly.
So the ESP32-S3 is definitely executing setup() and loop() after flashing. The problem appears to be specifically the serial output path.
Current platformio.ini
I also explicitly enabled the S3 native USB CDC settings:
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
    -DARDUINO_USB_MODE=1
    -DARDUINO_USB_CDC_ON_BOOT=1
    adafruit/Adafruit NeoPixel
After a clean rebuild, the build output contains:
Compiling .../FrameworkArduino/HWCDC.cpp.o
Compiling .../FrameworkArduino/USB.cpp.o
Compiling .../FrameworkArduino/USBCDC.cpp.o
So the USB CDC-related framework files are actually being compiled.
I also checked the build environment and initially only had:
('ARDUINO_USB_MODE', 1),
which is why I added:
But even after adding it and doing a clean rebuild, Serial Monitor remains completely blank.
Second USB port
The second USB-C port is:
/dev/cu.usbmodem5C840017341
VID:PID=1A86:55D3
Description: USB Single Serial
This is the external USB-UART interface.
Uploading through this port currently does not work, while uploading through /dev/cu.usbmodem14301 works normally.
Very important comparison
A normal ESP32 (non-S3) works normally with Serial Monitor using the same general PlatformIO workflow.
The problem is specifically with this ESP32-S3.
I have also seen reports of ESP32-S3 + PlatformIO where:
  • firmware uploads successfully;
  • the application runs;
  • Serial Monitor connects;
  • but Serial.print() / Serial.println() produces no output.
I’m trying to determine whether this is:
  1. an Arduino-ESP32 HWCDC/USB CDC issue;
  2. a PlatformIO/espressif32 configuration issue;
  3. a framework version issue;
  4. a macOS/native USB-Serial-JTAG issue;
  5. a USB port/interface selection issue;
  6. or something specific to the ESP32-S3-DevKitC-1 board configuration.
The key symptom is:
ESP32-S3 firmware uploads successfully through /dev/cu.usbmodem14301, the firmware definitely runs (RGB test works), but Serial.println() produces absolutely nothing in PlatformIO Serial Monitor at 115200 baud.
Has anyone had this exact combination of symptoms on ESP32-S3 + PlatformIO + macOS, and what was the actual fix?
Is this post helpful?
Please refer to the platform.ini configuration that is known to work.
