I have loaded the esp32 (over USB initially) with the ElegantOTA examples and it works perfectly if I connect to the device with a web browser over WiFi and upload a .bin file but I can’t get it to work from PlatformIO direct.
Checking with Wireshark, Platformio is attempting to connect to the correct port on the esp32 via WiFi but with UDP. Is there a setting I need to put in Platformio.ini or somewhere else to make it use TCP?
mDNS is resolving to the correct IP address.
I have spent some time hunting for this and have found many problems associated with esp32 OTA (and fixes for most) but can find no reference to “upload_protocol = espota” using UDP or TCP.
This is my Platformio.ini file:
[env:esp12e]
board = nodemcu-32s
marvinroger/AsyncMqttClient@^0.9.0
ottowinter/ESPAsyncWebServer-esphome@^3.1.0
ayushsharma82/ElegantOTA@^3.1.0
upload_port = esp32-chint.local
upload_flags = --port=80
#upload_port = /dev/ttyUSB0
#upload_speed = 921600
build_flags=-DELEGANTOTA_USE_ASYNC_WEBSERVER=1
John.
