Hi there. I am having issues compiling for espressif32 type target; in particular, stuff like
• WiFi.mode
• WiFiClass member softAP
• WiFiClass member softAPIP
seems to be missing in the WiFi library resolved by ldf, which leads me to the conclusion, that a wrong type of WiFi library is being resolved by ldf. For some reason though, after editing or changing the platformio.ini file, it would sometimes pick the correct one, and sometimes not.
Here is my configuration considering platofrmio.ini:
; Redirecting...[env:heltec_wifi_lora_32]
upload_speed = 921600
upload_port = /dev/tty.SLAB_USBtoUARTplatform = espressif32
board = heltec_wifi_lora_32
lib_ldf_mode = off
lib_compat_mode = 0
lib_deps = U8g2, WiFi
Example code may look as follows:
* main.cpp
* Created on: 6 Mar 2018
* Author: anonymous
#include <WiFi.h>
void setup(){
WiFi.softAP("Foo", "Bar");
void loop(){
The resulting terminal output would be:
15:52:38 **** Incremental Build of configuration Default for project test-proj ****
platformio -f -c eclipse run
[Tue Mar 6 15:52:38 2018] Processing heltec_wifi_lora_32 (framework: arduino; lib_ldf_mode: off; lib_deps: U8g2, WiFi; platform: espressif32; upload_speed: 921600; board: heltec_wifi_lora_32; upload_port: /dev/tty.SLAB_USBtoUART; lib_compat_mode: 0)
LibraryManager: Installing id=942
Downloading...
Unpacking...
LibraryManager: Installing id=870
Downloading...
Unpacking...
Collected 20 compatible libraries
Library Dependency Graph ( http://bit.ly/configure-pio-ldf )
|-- <U8g2> v2.22.2
|-- <WiFi> v1.2.7
Compiling .pioenvs/heltec_wifi_lora_32/src/main.o
Generating partitions .pioenvs/heltec_wifi_lora_32/partitions.bin
Archiving .pioenvs/heltec_wifi_lora_32/libFrameworkArduinoVariant.a
Indexing .pioenvs/heltec_wifi_lora_32/libFrameworkArduinoVariant.a
Compiling .pioenvs/heltec_wifi_lora_32/FrameworkArduino/Esp.o
src/main.cpp: In function 'void setup()':
src/main.cpp:12:7: error: 'class WiFiClass' has no member named 'softAP'
Compiling .pioenvs/heltec_wifi_lora_32/FrameworkArduino/HardwareSerial.o
Compiling .pioenvs/heltec_wifi_lora_32/FrameworkArduino/IPAddress.o
Compiling .pioenvs/heltec_wifi_lora_32/FrameworkArduino/IPv6Address.o
Compiling .pioenvs/heltec_wifi_lora_32/FrameworkArduino/MD5Builder.o
*** [.pioenvs/heltec_wifi_lora_32/src/main.o] Error 1
========================== [ERROR] Took 10.24 seconds ==========================
15:52:48 Build Finished (took 10s.762ms)
