Esp32 latest pakage: 6.7
Hi All,
After updating the platformio using: pio pkg update
the serial output from my esp32 not working any more just showing some boot messages then Null, I tried to uninstall then reinstall platformio , on windows and linux , add this to the ini file: monitor_speed = 115200
monitor_rts = 0
monitor_dtr = 0
but still the same problem
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13232
load:0x40080400,len:3028
entry 0x400805e4
Null
I guess “Null” is the output from your sketch.
But without knowing your sketch and your platformio.ini this is just a guess.
Please try a simple Hello World sketch and let us know the content of your platformio.ini and the exact board you are using.
  Serial.println("Hello World");
void loop() {}
The code was working fine and the serial output too, Then I had a problem with wifi library so I tried to update the pio pkgs the problem appeared after the update.
I use esp32 dev module
with arduino framework
I also tried to compile an old version from my project that in production and tested for a long time , the problem happen also, So I think it’s not my code problem , I think maybe the new version has a bug or more configs must be configured !
Maybe the framework has been broken.
  • Close VS Code
  • Delete all “espressif32” folders in C:\Users\<username>\.platformio\platforms
  • Start VS Code
  • Wait until PlatformIO finished all tasks (reinstalling the platform)
