If there is a better place to ask this question (or a different community), I would appreciate a pointer. I’m struggling with an issue making an HTTPS call from my ESP32 application. I’m receiving an MBEDTLS_ERR_SSL_INVALID_RECORD error when attempting to make a connection to OpenWeatherMap, while another call succeeds. Based on all of my internet searches, it seems like MBEDTLS_ERR_SSL_INVALID_RECORD might be memory related. However, I have not figured out how to control the memory allocated to the buffer.
I’m running on:
board = esp32doit-devkit-v1
Here is some output from the process that fails:
[V][HTTPClient.cpp:245] beginInternal(): url: http://api.openweathermap.org/data/2.5/weather?zip=55960&units=imperial&APPID=xxxxx
[D][HTTPClient.cpp:293] beginInternal(): protocol: http, host: api.openweathermap.org port: 80 url: /data/2.5/weather?zip=55960&units=imperial&APPID=xxxxx
Executing GET request
[D][HTTPClient.cpp:579] sendRequest(): request type: ‘GET’ redirCount: 0[V][ssl_client.cpp:59] start_ssl_client(): Free internal heap before TLS 235864
[V][ssl_client.cpp:65] start_ssl_client(): Starting socket
[V][ssl_client.cpp:104] start_ssl_client(): Seeding the random number generator
[V][ssl_client.cpp:113] start_ssl_client(): Setting up the SSL/TLS structure…
[I][ssl_client.cpp:127] start_ssl_client(): WARNING: Skipping SSL Verification. INSECURE!
[V][ssl_client.cpp:197] start_ssl_client(): Setting hostname for TLS session…
[V][ssl_client.cpp:212] start_ssl_client(): Performing the SSL/TLS handshake…
[E][ssl_client.cpp:36] _handle_error(): [start_ssl_client():216]: (-29184) SSL - An invalid SSL record was received
[E][WiFiClientSecure.cpp:133] connect(): start_ssl_client: -29184
[V][ssl_client.cpp:265] stop_ssl_socket(): Cleaning SSL connection.
[D][HTTPClient.cpp:1118] connect(): failed connect to api.openweathermap.org:80
[W][HTTPClient.cpp:1417] returnError(): error(-1): connection refused
GET request result code: -1
[D][HTTPClient.cpp:400] disconnect(): tcp is closed[V][ssl_client.cpp:265] stop_ssl_socket(): Cleaning SSL connection.
Can anyone suggest next steps?
Thanks!
Craig
