Dear sirs
I am using jlink for debug in ESP32 ; until now is working ok ; but in a new project is giving the next error and I can not start debug
COMPILATION OK
Linking .pio/build/esp32dev/firmware.elf
Retrieving maximum program size .pio/build/esp32dev/firmware.elf
Checking size .pio/build/esp32dev/firmware.elf
RAM: [== ] 21.6% (used 70720 bytes from 327680 bytes)
Flash: [========= ] 91.5% (used 2878214 bytes from 3145728 bytes)
Building .pio/build/esp32dev/firmware.bin
esptool.py v3.1
Merged 1 ELF section
======================== [SUCCESS] Took 122.03 seconds ========================
Reading symbols from /home/manuel/Documents/PlatformIO/Projects/esp32Marçalv8_vmlp/.pio/build/esp32dev/firmware.elf…
done.
PlatformIO: debug_tool = jlink
Open On-Chip Debugger v0.10.0-esp32-20210721 (2021-07-21-13:33)
Licensed under GNU GPL v2
For bug reports, read
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : J-Link ARM V8 compiled Nov 28 2014 13:44:46
Info : Hardware version: 8.00
Info : VTarget = 3.351 V
Info : clock speed 5000 kHz
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu0: Detected debug stubs @ 3ffcd318
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : accepting ‘gdb’ connection from pipe
Warn : No symbols for FreeRTOS!
Info : esp32.cpu0: Target halted, PC=0x40135156, debug_reason=00000000
Info : Set GDB target to ‘esp32.cpu0’
Info : esp32.cpu1: Target halted, PC=0x40135156, debug_reason=00000000
Warn : Not full dbg stub table 1 of 2
Info : esp32.cpu0: Target halted, PC=0x400928DA, debug_reason=00000001
Info : Flash mapping 0: 0x10020 → 0x3f400020, 2306 KB
Info : Flash mapping 1: 0x260018 → 0x400d0018, 412 KB
Info : Auto-detected flash bank ‘esp32.cpu0.flash’ size 4096 KB
Info : Using flash bank ‘esp32.cpu0.flash’ size 4096 KB
Info : Using flash bank ‘esp32.cpu0.irom’ size 416 KB
Info : Using flash bank ‘esp32.cpu0.drom’ size 2308 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
0x40135156 in _svfwprintf_r (data=, fp=, fmt0=, ap=…) at …/…/…/…/./newlib/libc/stdio/vfwprintf.c:924
924 …/…/…/…/./newlib/libc/stdio/vfwprintf.c: No existe el archivo o el directorio.
Loading section .flash.rodata, size 0x242070 lma 0x3f400020
Warn : address 0x3f641000 not writable
Warn : address 0x3f642000 not writable
.pioinit:12: Error in sourced command file:
Load failed
Load failed
FINALLY DO NOT START
Any one can help
Many thanls
