I am having trouble importing the ble_mesh_console example and compiling it. The compiler complains it does not find the files. I also do not see any reference to it in the Library manager.
examples\bluetooth\esp_ble_mesh\ble_mesh_console
Is there a step-by-step example on how to import these complex projects. I did try to create a default project from the built in examples and then copied the files over but it still does not want to compile.
In general: Always watch the console output regarding package version (and Releases · platformio/platform-espressif32 · GitHub) what ESP-IDF version you’re working with. Importing examples from the master
version of ESP-IDF while working on a lower stable release version often goes wrong.
Next, if a file is missing, go into the repo and press the “Go to file” button and type in the name of the missing file. This will lead you to components/bt/esp_ble_mesh/mesh_common/include/mesh_config.h
. The file being inside the esp_ble_mesh
component folder component suggests that you have not properly enabled the component via sdkconfig
as documented. The project has a sdkconfig.defaults
with the needed default settings – if you copied this file into your project too, it will however only take effect if you delete your sdkconfig
file and run pio run -t menuconfig
(per linked docs), it will then draw from those settings at regeneration. Once these settings are enabled properly (especially CONFIG_BLE_MESH
and friends…), the project should compile just fine.
Also note that the project uses a custom partition table.
so you will also have to inform PlatformIO about this per documentation.
