I am coding a project that uses HomeSpan
on the ESP32, and when I try to build my code, I get the following error:
fatal error: DNSServer.h: No such file or directory
I have tried adding DNSServer
to the platformio.ini
file lib_deps
section, but that leads to further errors with other files. I have also tried adding lib_ldf_mode = chain+
and lib_ldf_mode = deep+
, but adding these leads to errors with files like Network.h
Here is my current platformio.ini file:
[env]
lib_deps = homespan/HomeSpan@^2.1.0
[env:node32s]
board = node32s
The DNSServer.h
header is being included in some part of HomeSpan’s headers.
To fix this, simply add an #include <DNSServer.h>
before #include <HomeSpan.h>
. Also a include <Arduino.h>
is a good idea.
So the minimized “01-SimpleLightBulb
” example should look like this:
homeSpan.begin(Category::Lighting, "HomeSpan LightBulb");
new SpanAccessory();
new Service::AccessoryInformation();
new Characteristic::Identify();
new Service::LightBulb();
new Characteristic::On();
homeSpan.poll();
Note:
This library requires Arduino 3.x. Therefore you have to use pioarduino.
You also have to change the partition layout, as the app will exceed the default size of 1310720 Bytes.
[env]
[env:node32s]
platform = https://github.com/pioarduino/platform-espressif32/releases/download/53.03.11/platform-espressif32.zip
board = node32s
board_build.partitions = huge_app.csv
Result:
Processing node32s (platform: https://github.com/pioarduino/platform-espressif32/releases/download/53.03.11/platform-espressif32.zip; board: node32s; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/node32s.html
PLATFORM: Espressif 32 (53.3.11) > Node32s
- framework-arduinoespressif32 @ 3.1.1
- framework-arduinoespressif32-libs @ 5.3.0+sha.cfea4f7c98
- tool-esptoolpy @ 4.8.5
- tool-mklittlefs @ 3.2.0
- tool-riscv32-esp-elf-gdb @ 14.2.0+20240403
- tool-xtensa-esp-elf-gdb @ 14.2.0+20240403
- toolchain-xtensa-esp-elf @ 13.2.0+20240530
Found 42 compatible libraries
|-- HomeSpan @ 2.1.0
|-- DNSServer @ 3.1.1
Retrieving maximum program size .pio/build/node32s/firmware.elf
Checking size .pio/build/node32s/firmware.elf
RAM: [== ] 18.6% (used 61016 bytes from 327680 bytes)
Flash: [===== ] 45.6% (used 1433760 bytes from 3145728 bytes)
