I’m attempting to debug an ESP32 arduino application and breakpoints that I set in a library file pause execution about 1 time in 10 restarts. Why is this and how can I make it more reliable? Restarting debugging takes forever and often breaks. ESP-prog tool.
Bad cables to too high debug frequency? See How do I upload arduino code to esp32 using ESP-Prog - #16 by maxgerhardt
I think the cable is fine.
Default is 20000. I don’t see an option to lower that for esp-prog.
Does anyone know how to lower the debug frequency for the esp-prog?
Can you temporarily edit the adapter_khz
value in the filepath given in the link above and see if that helps?
I missed that filepath somehow.
I tried lowering it to 10000 and got the same results. PIO refuses to stop at the breakpoint I set within my syncTime() function. Am I doing it right?
I tried clearing all breakpoints, starting debugging after cleaning the build and restarting vscode then setting the breakpoint after it hit the temp breakpoint and get the following error message:
Hi @Daemach! There are three possible sources of your problem:
- Hardware issues (bad wiring, defective probe, etc)
- Issues with tools provided by Espressif team (GDB, OpenOCD)
- Issues with PlatformIO debug instruments
To exclude the first two:
- Do you have any other debug probe at hand? What board do you use?
- Can you try to debug your board using only Espressif tools in command line mode?
I don’t have another debug probe. I’m using the esp-prog on an ESP32 WROOM
I don’t know how to debug outside PIO but I’ll try if you can point me in the right direction.
Official setup from ESP-IDF written for Eclipse and their openocd + gdb solution is here: JTAG Debugging - ESP32 - — ESP-IDF Programming Guide latest documentation. It’s quite lengthy though.
