I,am refer to this tutorial to set up the gdb server, and I can also connect to the Raspberry Pi smoothly in VScode, but this error occurs when I run debug
Reading symbols from /Users/caiyousheng/Documents/PlatformIO/Projects/ESP32_Debug_Test/.pio/build/nodemcu-32s/firmware.elf...
PlatformIO: debug_tool = custom
undefined0000606:WARNING:gdb_server:pyocd-gdbserver is deprecated; please use the new combined pyocd tool.
0x4000f979 in ?? ()
JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Unexpected OCD_ID = 00000000
[esp32.cpu0] Debug controller was reset.
[esp32.cpu0] Core was reset.
[esp32.cpu0] Target halted, PC=0x500000CF, debug_reason=00000000
[esp32.cpu0] Target halted, PC=0x40000400, debug_reason=00000000
[esp32.cpu1] Debug controller was reset.
[esp32.cpu1] Core was reset.
[esp32.cpu1] Target halted, PC=0x40000400, debug_reason=00000000
[esp32.cpu0] Target halted, PC=0x4009260E, debug_reason=00000001
Failed to get flash maps (4294967290)!
Failed to get flash mappings (-4)!
Auto-detected flash bank 'esp32.cpu1.flash' size 4096 KB
Using flash bank 'esp32.cpu1.flash' size 4096 KB
** Programming Started **
couldn't open /Users/caiyousheng/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/bin/bootloader_dio_40m.bin
** Programming Failed **
.pioinit:15: Error in sourced command file:
Protocol error with Rcmd
Loop <_UnixSelectorEventLoop running=False closed=True debug=False> that handles pid 62115 is closed
platformio.ini :
[env:nodemcu-32s]
platform = https://github.com/platformio/platform-espressif32.git
board = nodemcu-32s
debug_tool = custom
debug_port = raspberrypi.local:3333
debug_server = pyocd-gdbserver
upload_port = /dev/cu.SLAB_USBtoUART
Dev Board:AI-thinker NodeMCU-32S
