Hi all,
I’ve got this issue, when I make a new buffer array, and using miwagner/esp32CAN try to send a message it sends out Remote Frame (empty frame), unless I introduce 1 ms delay(). If I use buffer array that I’ve previously created, there is no issue. I’m using NODEMCU ESP32, Arduino Framework. If anyone could explain why, would be appreciated.
Thank you,
Adomas
