ESP32-C3 does not connect to wifi
I purchased 10 QT Py ESP32-C3 WiFi Dev boards. 9 of 10 will not connect to WiFi.
Code pasted below - Wi.Status() returns WL_DISCONNECTED on every attempt. After searching this appears to be a widespread problem with this version of the ESP32-C3. This is a good discussion on the issue including input from AdaFruit GitHub: Unable to connect to WiFi network on ESP32-C3 · Issue #6430 · espressif/arduino-esp32 · GitHub
Questions:
  • Is there an issue with the ESP32-C3 impacting WiFi?
  • Is there a firmware solution for this WiFi issue? Is so, what?
  • Does the -S2 or -S3 have the same issue?
  • Should I replace my C3 boards with S3?
Any help is greatly appreciated.
boolean connenctToWiFi(int wifiMaxAttemps) {
    int wifiAttempts = 0;
    int wifiCounter = 0;
    WiFi.mode(WIFI_STA);
    WiFi.disconnect();
    delay(100);
    WiFi.begin(ssid, password);
        Serial.printf("%i.", WiFi.status());
        delay(100);
        if (++wifiCounter == 10 ) {
            Serial.println();
            wifiCounter = 0;
            wifiAttempts++;
        if (wifiAttempts > wifiMaxAttemps) {
            Serial.println("\nMax connect attempts. Restarting.\n");
            delay(100);
            ESP.restart();
    return true;
