When including the Adafruit GPS library and Espressif’s SD library, I get a list of errors. Somehow both libraries collide, but I currently don’t see why.
platformio.ini:
adafruit/Adafruit GPS Library @ 1.5.2
lib_ldf_mode = deep
main.cpp:
#include <Adafruit_GPS.h>
#include <SD.h>
Errors:
In file included from .pio/libdeps/esp32dev/SD/utility/Sd2Card.h:26:0,
from .pio/libdeps/esp32dev/SD/utility/SdFat.h:29,
from .pio/libdeps/esp32dev/SD/SD.h:25,
from src/main.cpp:4:
.pio/libdeps/esp32dev/SD/utility/Sd2PinMap.h:371:2: error: #error Architecture or board not supported.
Compiling .pio/build/esp32dev/lib544/Adafruit GPS Library/Adafruit_GPS.cpp.o
Compiling .pio/build/esp32dev/lib544/Adafruit GPS Library/NMEA_build.cpp.o
Compiling .pio/build/esp32dev/lib544/Adafruit GPS Library/NMEA_data.cpp.o
Compiling .pio/build/esp32dev/lib544/Adafruit GPS Library/NMEA_parse.cpp.o
Archiving .pio/build/esp32dev/lib002/libSPI.a
Indexing .pio/build/esp32dev/lib002/libSPI.a
Compiling .pio/build/esp32dev/libd81/SD/File.cpp.o
In file included from .pio/libdeps/esp32dev/SD/utility/SdFat.h:29:0,
.pio/libdeps/esp32dev/SD/utility/Sd2Card.h:65:37: error: ‘SS_PIN’ was not declared in this scope
uint8_t const SD_CHIP_SELECT_PIN = SS_PIN;
.pio/libdeps/esp32dev/SD/utility/Sd2Card.h:68:31: error: ‘MOSI_PIN’ was not declared in this scope
uint8_t const SPI_MOSI_PIN = MOSI_PIN;
.pio/libdeps/esp32dev/SD/utility/Sd2Card.h:70:31: error: ‘MISO_PIN’ was not declared in this scope
uint8_t const SPI_MISO_PIN = MISO_PIN;
.pio/libdeps/esp32dev/SD/utility/Sd2Card.h:72:30: error: ‘SCK_PIN’ was not declared in this scope
uint8_t const SPI_SCK_PIN = SCK_PIN;
