You should call WiFi.softAPConfig before WiFi.softAP
configurator_wifi is undefined so you should define it or remove it.
Port 567 is a non standard port. If you are using this port, make sure your client can connect to this port.
The default port is 80. Try that one first. -
You don’t need to set the wifi to off by calling WiFi.mode(WIFI_OFF). Is enough to disconnect.
If you want to use custom IP, you should define it as a int array: IPAddress ipDev={192,168,24,16};
Not as a string like you did.
Check the IPAddress class constructor:
IPAddress(uint8_t first_octet, uint8_t second_octet, uint8_t third_octet, uint8_t fourth_octet);
About strings: You should NOT include “string” into the project. String is already defined in Wstring.h that is included into Arduino framework.
Also you don’t need to include “IPAddress.h” since is already included into WiFi.h. Check inclusion tree…
My advice is to start from the WifiAccessPoint example, see it work, then you can expand from that.
Below you can find this example:
WiFiAccessPoint creates a WiFi access point and provides a web server on it.
Steps:
1. Connect to the access point "yourAp"
2. Point your web browser to http://192.168.4.1/H to turn the LED on or http://192.168.4.1/L to turn it off
OR
Run raw TCP "GET /H" and "GET /L" on PuTTY terminal with 192.168.4.1 as IP address and 80 as port
Created for arduino-esp32 on 04 July, 2018
by Elochukwu Ifediora (fedy0)
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiAP.h>
#define LED_BUILTIN 2 // Set the GPIO pin where you connected your test LED or comment this line out if your dev board has a built-in LED
// Set these to your desired credentials.
const char *ssid = "yourAP";
const char *password = "yourPassword";
WiFiServer server(80);
void setup()
pinMode(LED_BUILTIN, OUTPUT);
Serial.println();
Serial.println("Configuring access point...");
// You can remove the password parameter if you want the AP to be open.
WiFi.softAP(ssid, password);
IPAddress myIP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(myIP);
server.begin();
Serial.println("Server started");
void loop()
WiFiClient client = server.available(); // listen for incoming clients
if (client)
{ // if you get a client,
Serial.println("New Client."); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected())
{ // loop while the client's connected
if (client.available())
{ // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n')
{ // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0)
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("Click <a href=\"/H\">here</a> to turn ON the LED.<br>");
client.print("Click <a href=\"/L\">here</a> to turn OFF the LED.<br>");
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
break;
else
{ // if you got a newline, then clear currentLine:
currentLine = "";
else if (c != '\r')
{ // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Check to see if the client request was "GET /H" or "GET /L":
if (currentLine.endsWith("GET /H"))
digitalWrite(LED_BUILTIN, HIGH); // GET /H turns the LED on
if (currentLine.endsWith("GET /L"))
digitalWrite(LED_BUILTIN, LOW); // GET /L turns the LED off
// close the connection:
client.stop();
Serial.println("Client Disconnected.");
