I am trying to build the scan example from the official repository: esp-idf/scan.c at master · espressif/esp-idf · GitHub
It seems that esp_netif.h
header is not present in PlatformIO. Anyone knows how can I solve this issue?
> Executing task in folder esp-wifi: platformio run <
Processing esp32dev (platform: https://github.com/platformio/platform-espressif32.git; board: esp32dev; framework: espidf)
PLATFORM: Espressif 32 1.12.0 #9bc9c3a > Espressif ESP32 Dev Module
- framework-espidf 3.40000.200303 (4.0.0)
- tool-cmake 3.16.4
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.190618 (2.28.51)
- toolchain-xtensa32 2.80200.200226 (8.2.0)
Found 0 compatible libraries
Compiling .pio/build/esp32dev/esp-idf/src/main.c.o
Archiving .pio/build/esp32dev/esp-idf/app_update/libapp_update.a
Indexing .pio/build/esp32dev/esp-idf/app_update/libapp_update.a
In file included from /Users/kdubovikov/.platformio/packages/framework-espidf/components/esp_common/include/esp_timer.h:44,
from /Users/kdubovikov/.platformio/packages/framework-espidf/components/freertos/include/freertos/portmacro.h:84,
from /Users/kdubovikov/.platformio/packages/framework-espidf/components/freertos/include/freertos/portable.h:96,
from /Users/kdubovikov/.platformio/packages/framework-espidf/components/freertos/include/freertos/FreeRTOS.h:105,
from src/main.c:12:
src/main.c: In function 'wifi_scan':
src/main.c:104:21: error: implicit declaration of function 'esp_netif_init'; did you mean 'esp_wifi_init'? [-Werror=implicit-function-declaration]
ESP_ERROR_CHECK(esp_netif_init());
/Users/kdubovikov/.platformio/packages/framework-espidf/components/esp_common/include/esp_err.h:118:31: note: in definition of macro 'ESP_ERROR_CHECK'
esp_err_t __err_rc = (x); \
src/main.c:106:5: error: unknown type name 'esp_netif_t'; did you mean 'esp_err_t'?
esp_netif_t *sta_netif = esp_netif_create_default_wifi_sta();
esp_err_t
src/main.c:106:30: error: implicit declaration of function 'esp_netif_create_default_wifi_sta' [-Werror=implicit-function-declaration]
src/main.c:106:30: warning: initialization of 'int *' from 'int' makes pointer from integer without a cast [-Wint-conversion]
src/main.c:19:32: error: 'CONFIG_EXAMPLE_SCAN_LIST_SIZE' undeclared (first use in this function); did you mean 'DEFAULT_SCAN_LIST_SIZE'?
#define DEFAULT_SCAN_LIST_SIZE CONFIG_EXAMPLE_SCAN_LIST_SIZE
src/main.c:112:23: note: in expansion of macro 'DEFAULT_SCAN_LIST_SIZE'
uint16_t number = DEFAULT_SCAN_LIST_SIZE;
src/main.c:19:32: note: each undeclared identifier is reported only once for each function it appears in
src/main.c:113:22: warning: unused variable 'ap_info' [-Wunused-variable]
wifi_ap_record_t ap_info[DEFAULT_SCAN_LIST_SIZE];
cc1: some warnings being treated as errors
Compiling .pio/build/esp32dev/esp-idf/coap/libcoap/src/encode.c.o
Compiling .pio/build/esp32dev/esp-idf/coap/libcoap/src/mem.c.o
Compiling .pio/build/esp32dev/esp-idf/coap/libcoap/src/net.c.o
Compiling .pio/build/esp32dev/esp-idf/coap/libcoap/src/option.c.o
Compiling .pio/build/esp32dev/esp-idf/coap/libcoap/src/pdu.c.o
Compiling .pio/build/esp32dev/esp-idf/coap/libcoap/src/resource.c.o
*** [.pio/build/esp32dev/esp-idf/src/main.c.o] Error 1
======================================================================= [FAILED] Took 8.84 seconds =======================================================================
My platformio.ini
platform = GitHub - platformio/platform-espressif32: Espressif 32: development platform for PlatformIO
framework = espidf
upload_speed = 115200
I have noticed that netif is missing from the esp-idf components at /Users/kdubovikov/.platformio/packages/framework-espidf/components
. It is present in the official IDF repository though: github. com/espressif/esp-idf/tree/master/components/esp_netif.
