Basic Question: Why can’t I compile something with
“include <led_strip.h>”
in an espressif32 project? This is with framework-espidf v 5.0.0 so I don’t think this is related to older questions that have to do with PlatformIO only supporting v4.4.0 and earlier.
This seems to be functionality that is located/included in IDF Component Registry (espressif.com) but this does not show up in a PlatformIO library search.
How do I bring in esp-idf components??
Executing task: C:\Users\jeffr.platformio\penv\Scripts\platformio.exe run
Processing esp32-s3-devkitc-1 (platform: espressif32; board: esp32-s3-devkitc-1; framework: espidf)
Verbose mode can be enabled via-v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 (6.0.1) > Espressif ESP32-S3-DevKitC-1-N8 (8 MB QD, No PSRAM)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot->bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-espidf @ 3.50000.0 (5.0.0)
- tool-cmake @ 3.16.4
- tool-esptoolpy @ 1.40400.0 (4.4.0)
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-riscv32-esp @ 11.2.0+2022r1
- toolchain-xtensa-esp32s3 @ 11.2.0+2022r1
Reading CMake configuration…
Found 0 compatible libraries
Scanning dependencies…
Compiling .pio\build\esp32-s3-devkitc-1\src\main.o
src/main.c:5:10: fatal error: led_strip.h: No such file or directory
- Looking for led_strip.h dependency? Check our library registry!
- CLI > platformio lib search “header:led_strip.h”
- Web > PlatformIO Registry
5 | #include <led_strip.h>
compilation terminated.
*** [.pio\build\esp32-s3-devkitc-1\src\main.o] Error 1
========================== [FAILED] Took 4.81 seconds ==========================
- The terminal process “C:\Users\jeffr.platformio\penv\Scripts\platformio.exe ‘run’” terminated with >exit code: 1.
- Terminal will be reused by tasks, press any key to close it.
