ESP-IDF Components not included for build
Running Platformio using VSS on MacOS
I have added a component from another dev to a new root level components folder as per the instructions at Espressif IoT Development Framework — PlatformIO latest documentation
By adding a new component to an optional folder called components in the root of your project. This folder will be automatically scanned for valid components.
My project is structured as follows:
├── CMakeLists.txt
├── components
│   └── CAN
│       ├── CAN.c
│       ├── Kconfig
│       ├── component.mk
│       └── include
│           ├── CAN.h
│           ├── CAN_config.h
│           └── can_regdef.h
├── include
│   ├── app_config.h
├── lib
│   ├── id_list
│   └── str_util
├── platformio.ini
├── sdkconfig
├── src
│   ├── CMakeLists.txt
│   ├── main.c
└── test
When I try to build the app, I get the following error
src/main.c:13:10: fatal error: CAN_config.h: No such file or directory
* Looking for CAN_config.h dependency? Check our library registry!
* CLI  > platformio lib search "header:CAN_config.h"
* Web  > https://platformio.org/lib/search?query=header:CAN_config.h
 #include "CAN_config.h"
compilation terminated.
It appears that the components directory is not scanned. Do I need to add any extra configuration?
Maybe the components need a CMake style CMakeLists.txt too to work, but yours only has thte Makefile (example)? Does the second way via modifying CMakeLists.txt work better?
list(APPEND EXTRA_COMPONENT_DIRS CAN)
Are you saying that the included component needs its own CMakeLists.txt file (under the CAN folder)?
btw I did try the second way too but that didn’t seem to work either.
At the moment, I have copied the CAN folder under lib and that does work, but then it’s not really an external component anymore!
I will try this again and repot back. Thanks
