My windows user path is as follows: C:/Users/Serial’S/
That does not seem to go well with Atom / PlatformIO
2 of the errors i get are:
“C:/Users/Serial’S/.platformio/packages/toolchain-xtensa/bin/xtensa-lx106-elf-g++.exe” not found
ess.target.send (internal/child_process.js:540:16)
at Task.module.exports.Task.send (C:\Users\Serial’S\AppData\Local\atom\app-1.17.2\resources\app\src\task.js:119:1)
at PlatformIOTerminalView.module.exports.PlatformIOTerminalView.input (file:///C:/Users/Serial’S/.atom/packages/platformio-ide-terminal/lib/view.coffee:264:17)
at Terminal. (file:///C:/Users/Serial’S/.atom/packages/platformio-ide-terminal/lib/view.coffee:142:8)
at Terminal.EventEmitter.emit (C:\Users\Serial’S.atom\packages\build\node_modules\term.js\src\term.js:109:12)
at Terminal.handler (C:\Users\Serial’S.atom\packages\build\node_modules\term.js\src\term.js:3493:8)
at Terminal.keyPress (C:\Users\Serial’S.atom\packages\build\node_modules\term.js\src\term.js:3243:8)
at HTMLDocument. (C:\Users\Serial’S.atom\packages\build\node_modules\term.js\src\term.js:608:29)
Any idea how could i go from here?
This is when dealing with an esp8266 project
Thanks in advance
Julián
Do you have problem if you open PIO IDE Terminal manually (see Terminal icon on toolbar) and type
pio run
Does it work?
This is what happens when I try to type (i can’t even)
i can’t use the terminal pretty much.
Stack trace reads as follows:
Error: channel closed
at ChildProcess.target.send (internal/child_process.js:540:16)
It’s the same one i copied above but complete
Could you try PlatformIO IDE for VSCode? Does it work?
